Please Help! IP phones Unprovisioned, Can't Ping, Or Register
ericbell8
I don't have any more hair to pull out! I've been stuck trying to register these phones for the last month or so. I know I'm missing a small detail, it's always something small that's missed. Can someone please look over my configures and point me in the right direction. It will be well appreciated, thanks.
Please try again!
Leonardo Santana
*** Rate All Helpful Responses***
25 Replies 25
Leonardo Santana
Hello i cant see your config file!
Leonardo Santana
I can't figure out how to attach another file.
I've posted the full configurations.
Bruno Rangel
Hi Eric
Ensure that your DHCP option 150 is correct. Try change it to:
ip dhcp pool ITS
option 150 ip 192.168.4.1
Please rate this post.
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Thanks for the respone. The TFTP Server (PC) is set for option 150 ip 192.168.3.22. Does it still need to be changed?
The TFTP is the IP Address of the CME!
Leonardo Santana
Ok. Is it the dhcp ip address on the fa0/0.1 interface (192.168.3.24) or ip address on the fa0/0.2 interface (192.168.4.1)?
Hi Eric
Check your Option 150 try change to ip of CUCME (192.168.4.1) from this Link that Leonardo sent (+5) look the section Router-Based TFTP Services for IP Phone Firmware Files.
Cheers
Bruno Rangel
option 150 ip 192.168.4.1 didn't work.
Leonardo Santana
Hello use this guide is very good:
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/6346-102-1-20737/CCNA-Voice%20VoIP.pdf
Check your networks config too!
Leonardo Santana
This link is asking for an Outlook Web App sign. I don't have an account, do I need one?
Please try again!
Leonardo Santana
Thanks, the guide worked. I just tweaked a few configures and the SCCP phone up. But, the SIP phone is the issue now.
ericbell8
The phones have a static IP address of 192.168.4.2 and 192.168.4.3
