04-12-2018 04:38 AM - edited 03-17-2019 12:36 PM
We have a Telephony platform linked to different locations across the world via sip trunks, we have a problem with 1 site using an old system (Nortel 1k), I think the sip trunk is configured as it should be, added the normalization script, and i'm now suspecting the DNS, here's my analysis:
replaced CUCM SIP trunk with a Voice gateway sip trunk, in both situations we can make calls towards that site, but can't receive, I did a debug of SIP messages, I see in the invites received that the Nortel call manager sends : Extension@domain.com, while we send Extension@cucmipaddress... I presume the DNS is the problem and I have to change it and use the client's DNS
I want to knowif there's any potential problems if I make that change
Solved! Go to Solution.
04-15-2018 05:27 AM
Hi there,
This has nothing to do with DNS resolution. If CUCM is receiving "Extension@domain.com", CUCM will not process the request unless the domain is configured in either its CFQDN ( cluster fully qualified domain name) or its OTLD ( organization top level domain name). You can easily add the domain as follows:
CUCM>enterprise parameter> cluster fully qualified domain name> add the domain here...
04-14-2018 05:01 AM - edited 04-15-2018 06:45 AM
04-16-2018 03:23 AM
04-14-2018 08:23 AM
What is the disconnect reason code? Can you provide "debug ccsip messages" from your GW?
04-16-2018 08:34 AM
04-15-2018 05:27 AM
Hi there,
04-16-2018 03:23 AM
04-18-2018 06:50 AM
