Presence backup error
bagnolini
Hi guys,
I receive this error every time I perform a Presence Backup...any idea?
I got a cluster with 2 servers and the System version is 9.1.1.10000-8
Server : CR1PRD108
Feature : IM_AND_PRESENCE
Component : CUP
Time Completed: 2013-06-12-10-16-08
Result Code : 1-Please check the component logs for further details.
Result String : ERROR
ready for backup
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
Traceback (most recent call last):
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 66, in ?
REQUIRED = REQUIRED + getDirSize(os.path.join(BASEDIR, dir))
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 58, in getDirSize
os.path.walk(dir, calcDirSize, sizes)
File "/usr/lib/python2.4/posixpath.py", line 290, in walk
func(arg, top, names)
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 48, in calcDirSize
stats = os.stat(os.path.join(dir, file))
OSError: [Errno 2] No such file or directory: '/usr/local/sip/.security/proxy/trust-certs/.0'
----> END Standard Error
Server : CR1PRD108
Component : CUP
ready for backup
fjlopezderego
    Did you find out how to solve this problem? We have the same trouble after updating the CUP certificates.
Thanks!
Michael Endler
the error message '/usr/local/sip/.security/proxy/trust-certs/.0' can only be fixed by cisco TAC.
They have to go on the CLI with root access to delete a position in the trust store, which starts with .0
There is no workaround you can fullfill, like renewing certificats or resarting drf services
Regards Michael
PetrTucek
Hello TAC is not always needed. I had same errror message and I just need regenerate ipsec certificate on cucm publisher and imp presence, then reload DRF Master and Local and backup works perfectly. (CUCM 12.5)
Regards Petr
