04-30-2013 08:50 AM - edited 03-16-2019 05:04 PM
I have three card types
card type t1 0 0
card type t1 0 1
card type t1 1 1
Clocking in currently configured as
network-clock-participate slot 1
network-clock-participate wic 0
no network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
Controller T1 0/0/0 , T 0/0/1 and Controller T1 1/0 and 1/1 are used for our 4 T1 connections (MPLS)
I want to add a PRI to controller 0/1/0. When I try and configure the controller for the PRI I get the following:
rtr-2911 (config-controller)#pri-group timeslots 1-24 service mgcp
%Please configure network-clock-participate wic 1 first
%Insufficient resources to create pri-group - it has been removed
How do I go about configuring the clocking correctly to allow for the PRI?
Solved! Go to Solution.
04-30-2013 10:10 AM
Ah.. got it. As far as PVDM - I have two modules install PVDM3-16 and PVDM3-64
hw-module pvdm 0/0
hw-module pvdm 0/1
04-30-2013 01:47 PM
Please cnfigure this..
Conf t
voice-card 0
dspfarm
dsp services dspfarm
Then ensure you have
And then try and configure your pris again
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-30-2013 09:32 AM
You will likely have to configure 'clock source independent' on the controller before adding the PRI group. But however you modify it, make sure you have the clocking situation coordinated with the provider so there will be no conflicts or slips on the line.
04-30-2013 10:02 AM
You cant configure PRI without cnfiguring network participate on the port. So you need to configure
%Insufficient resources to create pri-group---Means you dnt have enugh dsp to create the pris..You need to add PVDM to your router
04-30-2013 10:10 AM
04-30-2013 10:21 AM
But they have been allocated to something else..xcoding, conferencing etc..The gateway doesnt see any free resources,,
send me a show run and a show diag
04-30-2013 12:27 PM
I attached the the two to my previous comment
04-30-2013 01:47 PM
Conf t
voice-card 0
dspfarm
