Problem calling CUCM extention from CME extention
EDDY MULDER
I have Cucm 7.x and on a remote location a CME (Call manager Express).
On the cucm several phones configured with extention 10xx
On CME the phones have extention 2xx
From CUCM extention i can call an extention on the remote location
I am unable to call from the remote location the CUCM Extention
As debug i used the following:
debug voice ccapu inout
When extention 1016 calls 201 , this extention is presented as 181016 (so 18 will be the shordial code for the CME extention calling CUCM extention)
Debug output  : successfull callsetup from cucm to cme.txt
When i try to cal from 2xx an 10xx extenion (calling 1810xx) i see the following on my debug(file :Failed callsetup from cme.txt)
What you see hapening is that for Cisco-username and cisco ani a increasing time the prefix is added.
at the end you see:
cisco-username=181818201
   ----- ccCallInfo IE subfields -----
   cisco-ani=181818201
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=181016cisco-username=181818201
   cisco-ani=181818201
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=181016
i have configured the following debug on the CME router.
The following dialpeer is configured on the CME:
Dial-peer voice 5 voip
destination-pattern 18.T
Session target ipv4: <IP CUCM>
dtmf-relay h245-alphanumeric
codec g711ulaw
novad
What is causing this strange issue.
Eddy Mulder
Chris Deren
Is your H323 GW on CUCM defined with correct number of sigDigits and Calling Search Space?
Chris
Do you have this configured:
h323-gateway voip bind srcaddr ip_address
h323-gateway voip interface
They should be matching the IP you used in CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Vipul Jindal
checked the traces and you are hitting
Feb  8 15:21:19: //4820/FE4E600E8638/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48CEEFA0, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=201,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=181016(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=5600, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
you are hitting Outgoing Dial-peer=5600
what is the this dial peer??
thanks,
Vipul jindal
