02-28-2015 10:49 AM - edited 03-17-2019 02:09 AM
Hi Experts - admittedly my ISR 2901 V02 and Call Manager Express isn't fully configured yet, but it at least does dial out ok (no dial in). This is not the reason for this post (though feel free to comment on inbound calling over viatalk).
My problem is, when I attempt to use a voice activated system, for example, credit card activation systems, they simply drop the call after the first set of voice commands are sent. At first I attributed this to missing caller ID, but that appears to be sent. Could this have something to do with the codec being used? I'm at a loss for where to dig in to this and googling is not providing any meaningful results.
The numbers I am calling at US north american 800 numbers. I will include my config, and can attach debug of session if someone thinks that's interesting. Thank you in advance for your help.
version 15.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service internal
service sequence-numbers
hostname ISGNAV01
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.154-3.M2.bin
boot-end-marker
logging buffered 10000000
no logging console
no logging monitor
aaa new-model
aaa session-id common
clock timezone PST -8 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip dhcp excluded-address 172.16.30.1
ip dhcp excluded-address 172.16.30.2
ip dhcp excluded-address 172.16.30.3
ip dhcp excluded-address 172.16.30.4
ip dhcp excluded-address 172.16.30.10
ip dhcp pool VOICE-INT
import all
network 172.16.30.0 255.255.255.0
default-router 172.16.30.1
dns-server 75.75.75.75 8.8.8.8
option 150 ip 172.16.30.1
ip dhcp pool static_APNAVO
host 172.16.30.2 255.255.255.0
client-identifier XXXXXXXXXXX
ip dhcp pool static_APNAVB
host 172.16.30.3 255.255.255.0
ip dhcp pool static_APNAVT
host 172.16.30.4 255.255.255.0
ip domain name chilloutroom.net
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 3600 min 3600
no update-callerid
authenticate redirecting-number
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice iec syslog
license udi pid CISCO2901/K9 sn XXXXXXXXXXX
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
file privilege 0
username XXXXXXXXXXX privilege 15 password 7 XXXXXXXXXXX
redundancy
notification-timer 120000
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ES_LAN$
ip address 172.16.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address XXXXXXXXXXX 255.255.255.248
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash0:/CME
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 XXXXXXXXXXX
logging trap debugging
tftp-server flash0:/phone/7925G/APPSH-1.4.6.3.SBN alias APPSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/CP7925G-1.4.6.3.LOADS alias CP7925G-1.4.6.3.LOADS
tftp-server flash0:/phone/7925G/GUIH-1.4.6.3.SBN alias GUIH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/JSYSH-1.4.6.3.SBN alias JSYSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/SYSH-1.4.6.3.SBN alias SYSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/JUIH-1.4.6.3.SBN alias JUIH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/TNUXH-1.4.6.3.SBN alias TNUXH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/TNUXRH-1.4.6.3.SBN alias TNUXRH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/WLANH-1.4.6.3.SBN alias WLANH-1.4.6.3.SBN
tftp-server flash0:/phone/7975/apps75.9-4-2TH1-1.sbn alias apps75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/cnu75.9-4-2TH1-1.sbn alias cnu75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/cvm75sccp.9-4-2TH1-1.sbn alias cvm75sccp.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/dsp75.9-4-2TH1-1.sbn alias dsp75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/jar75sccp.9-4-2TH1-1.sbn alias jar75sccp.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/SCCP75.9-4-2-1S.loads alias SCCP75.9-4-2-1S.loads
access-list 100 remark inside-out
access-list 100 permit ip 172.16.30.0 0.0.0.255 any
access-list 100 deny ip any any
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
description **Incoming Call from SIP Trunk VIATALK**
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description **Outgoing Call to SIP VIATALK**
destination-pattern [2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
destination-pattern 1[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4 voip
description **Outgoing Call to SIP VIATALK** (1+ long distance dialing)
destination-pattern 1..........
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
authentication username 19255551212 password 7 XXXXXXXXXXX
srv version 1
retry invite 2
retry register 10
mwi-server dns:slingshot.vtnoc.net expires 300 port 5060 transport udp
registrar dns:slingshot.vtnoc.net expires 3600
sip-server dns:slingshot.vtnoc.net
host-registrar
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 10
max-dn 20
ip source-address 172.16.30.1 port 2000
url services http://phone-xml.berbee.com/menu.xml
cnf-file location flash:
cnf-file perphone
load 7925 CP7925G-1.4.6.3.LOADS
load 7975 SCCP75.9-4-2-1S.loads
max-conferences 8 gain -6
web admin system name XXXXXXXXXXX secret 5 XXXXXXXXXXX
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 100
label Office
name Office
ephone-dn 2 dual-line
number 101
label LivingRoom
name LivingRoom
ephone 1
device-security-mode none
description Home Office
mac-address XXXXXXXXXXX
max-calls-per-button 4
type 7925
button 1:2
ephone 2
type 7975
button 1:1 2m2
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
ntp server us.pool.ntp.org
end
Solved! Go to Solution.
02-28-2015 12:41 PM
That's what I thought. I would start by opening a case with your SIP service provider.
For test purposes, try adding "no ip address trusted authenticate" under "voice service voip" and place an incoming call.
As far as the SIP messages go, I can see the provider asking for authentication, and then a lot of negotiation back and forth until the call drops.
FG
03-01-2015 11:50 AM
For test purposes, lets try adding the following:
voice service voip
sip
no rel1xx require "100rel"
Try that and let me know. Also make sure you are following up with your provider to make sure we have the sip timers configured to their standards.
Edit: And please debug ccsip messages when testing.
FG
02-28-2015 11:12 AM
Hi there,
Can you make all other calls successfully?
The fact that the IVR answers is a good sign, how many seconds before they disconnect the call? Codec mismatch usually disconnects the call as soon as the RTP stream starts.
Please place a call while debugging "debug ccsip messages" and post the results.
FG
02-28-2015 11:32 AM
Hi Francisco - thank you for your quick response. I can make outgoing calls ok. Incoming calls currently get a busy tone. So there are several levels of problems still going on.
Here you go. I have a lot of logging turned on. In this case, the voice prompt got through for the very beginning of a second set of prompts and started to respond, then simply dropped:
ISGNAV01#sho log
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 5585 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level debugging, 23689 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (10000000 bytes):
002306: Feb 28 11:17:09.102: //-1/397FB52581C3/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
002307: Feb 28 11:17:09.102: //-1/397FB52581C3/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2416DF80, Call Info(
Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20004, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002308: Feb 28 11:17:09.102: //-1/397FB52581C3/CCAPI/ccCheckClipClir:
In: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
002309: Feb 28 11:17:09.102: //-1/397FB52581C3/CCAPI/ccCheckClipClir:
Out: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
002310: Feb 28 11:17:09.102: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002311: Feb 28 11:17:09.102: :cc_get_feature_vsa malloc success
002312: Feb 28 11:17:09.102: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002313: Feb 28 11:17:09.102: cc_get_feature_vsa count is 1
002314: Feb 28 11:17:09.102: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002315: Feb 28 11:17:09.102: :FEATURE_VSA attributes are: feature_name:0,feature_time:617749624,feature_id:105
002316: Feb 28 11:17:09.102: //312/397FB52581C3/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
002317: Feb 28 11:17:09.102: //312/397FB52581C3/CCAPI/cc_process_call_setup_ind:
Event=0x22B9EFC0
002318: Feb 28 11:17:09.102: //312/397FB52581C3/CCAPI/ccCallSetContext:
Context=0x2455CB1C
002319: Feb 28 11:17:09.102: //312/397FB52581C3/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 312 with tag 20004 to app "_ManagedAppProcess_Default"
002320: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccCallSetupAck:
Call Id=312
002321: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
002322: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=312
002323: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
002324: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
002325: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccCallReportDigits:
(callID=0x138, digit_event=0x1, enable=TRUE, consume=FALSE)
002326: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=312
002327: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2416DF80, callID=0x138, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
002328: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x2416DF80, Call Id=312
002329: Feb 28 11:17:09.106: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
002330: Feb 28 11:17:12.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=312, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x2258F8, Rtp Expiration=0x0
002331: Feb 28 11:17:12.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=1, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
002332: Feb 28 11:17:12.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Call Entry(Handoff Depth=0)
002333: Feb 28 11:17:12.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Source Call Id=312, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x22D5F8, Rtp Expiration=0x0
002334: Feb 28 11:17:12.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=8, Duration=100,
002335: Feb 28 11:17:12.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002336: Feb 28 11:17:12.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Source Call Id=312, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x2352F8, Rtp Expiration=0x0
002337: Feb 28 11:17:12.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=0, Duration=100,
002338: Feb 28 11:17:12.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002339: Feb 28 11:17:12.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x23CFF8, Rtp Expiration=0x0
002340: Feb 28 11:17:12.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002341: Feb 28 11:17:12.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002342: Feb 28 11:17:12.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Source Call Id=312, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x244CF8, Rtp Expiration=0x0
002343: Feb 28 11:17:12.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=2, Duration=100,
002344: Feb 28 11:17:12.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002345: Feb 28 11:17:13.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Source Call Id=312, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x24C9F8, Rtp Expiration=0x0
002346: Feb 28 11:17:13.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=3, Duration=100,
002347: Feb 28 11:17:13.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002348: Feb 28 11:17:13.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x2546F8, Rtp Expiration=0x0
002349: Feb 28 11:17:13.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002350: Feb 28 11:17:13.214: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002351: Feb 28 11:17:13.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Source Call Id=312, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0x25C3F8, Rtp Expiration=0x0
002352: Feb 28 11:17:13.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
Source Call Id=312, Digit=6, Duration=100,
002353: Feb 28 11:17:13.414: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002354: Feb 28 11:17:13.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x2640F8, Rtp Expiration=0x0
002355: Feb 28 11:17:13.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002356: Feb 28 11:17:13.614: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002357: Feb 28 11:17:13.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x26BDF8, Rtp Expiration=0x0
002358: Feb 28 11:17:13.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002359: Feb 28 11:17:13.814: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002360: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x273AF8, Rtp Expiration=0x0
002361: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002362: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_digit_end:
002363: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallReportDigits:
(callID=0x138, digit_event=0x0, enable=FALSE, consume=FALSE)
002364: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallReportDigits:
002365: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2416DF80, callID=0x138, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
002366: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
002367: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_call_report_digits_done:
002368: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
002369: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x2455F6BC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
002370: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCheckClipClir:
002371: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCheckClipClir:
002372: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallSetupRequest:
Destination Pattern=1[2-9]..[2-9]......, Called Number=18002336111, Digit Strip=FALSE
002373: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccCallSetupRequest:
Called Number=18002336111(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Office
Account Number=, Final Destination Flag=FALSE,
Guid=397FB525-BEB5-11E4-81C3-ECAB8E7838B0, Outgoing Dial-peer=3
002374: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=18002336111
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
002375: Feb 28 11:17:14.014: //312/397FB52581C3/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3EBE699C, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=100,(Calling Name=Office)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=18002336111(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
002376: Feb 28 11:17:14.014: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002377: Feb 28 11:17:14.014: :cc_get_feature_vsa malloc success
002378: Feb 28 11:17:14.014: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002379: Feb 28 11:17:14.014: cc_get_feature_vsa count is 2
002380: Feb 28 11:17:14.014: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002381: Feb 28 11:17:14.014: :FEATURE_VSA attributes are: feature_name:0,feature_time:617749848,feature_id:106
002382: Feb 28 11:17:14.018: //313/397FB52581C3/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
002383: Feb 28 11:17:14.018: //313/397FB52581C3/CCAPI/ccCallSetContext:
Context=0x2455F66C
002384: Feb 28 11:17:14.018: //312/397FB52581C3/CCAPI/ccSaveDialpeerTag:
002385: Feb 28 11:17:14.018: //313/397FB52581C3/CCAPI/cc_api_call_proceeding:
Interface=0x3EBE699C, Progress Indication=NULL(0)
002386: Feb 28 11:17:14.206: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:18002336111@slingshot.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXXX:5060;branch=z9hG4bK1B62583
Remote-Party-ID: "Office" <sip:100@XXXXXXXX>;party=calling;screen=no;privacy=off
From: "Office" <sip:100@slingshot.vtnoc.net>;tag=EE182A8-1CDA
To: <sip:18002336111@slingshot.vtnoc.net>
Date: Sat, 28 Feb 2015 19:17:14 GMT
Call-ID: 3C6E7023-BEB511E4-81C8ECAB-8E7838B0@XXXXXXXX
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0964670757-3199537636-2177100971-2390243504
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1425151034
Contact: <sip:100@XXXXXXXX:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 5510 4897 IN IP4 XXXXXXXX
s=SIP Call
c=IN IP4 XXXXXXXX
t=0 0
m=audio 16548 RTP/AVP 0 8 101
c=IN IP4 XXXXXXXX
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
002387: Feb 28 11:17:14.222: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP XXXXXXXX:5060;received=XXXXXXXXXX;rport=65168;branch=z9hG4bK1B62583
Call-ID: 3C6E7023-BEB511E4-81C8ECAB-8E7838B0@XXXXXXXXXX
CSeq: 101 INVITE
Server: OpenSIPS (1.8.5-tls (x86_64/linux))
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25658 req_src_ip=XXXXXXXXXX req_src_port=65168 in_uri=sip:18002336111@slingshot.vtnoc.net:5060 out_uri=sip:18002336111@slings"
002388: Feb 28 11:17:14.222: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP XXXXXXXXXX:5060;received=XXXXXXXXXX;rport=65168;branch=z9hG4bK1B62583
To: <sip:18002336111@slingshot.vtnoc.net>;tag=1b73745810345c25dc91027d595549ab.a59c
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="slingshot.vtnoc.net", nonce="54f2147100012a2fc60a853cd4b5d47e942c86f973a1a8db", qop="auth"
Content-Length: 0
002389: Feb 28 11:17:14.222: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:18002336111@slingshot.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXX:5060;branch=z9hG4bK1B62583
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
002390: Feb 28 11:17:14.222: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP XXXXXXXXXX:5060;branch=z9hG4bK1B7D4F
Remote-Party-ID: "Office" <sip:100@XXXXXXXXXX>;party=calling;screen=no;privacy=off
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Contact: <sip:100@XXXXXXXXXX:5060>
Expires: 180
Proxy-Authorization: Digest username="19255551212",realm="slingshot.vtnoc.net",uri="sip:18002336111@slingshot.vtnoc.net:5060",response="5798abd775b88cb3f68040608cad87d2",nonce="54f2147101
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 5510 4897 IN IP4 XXXXXXXXXX
s=SIP Call
c=IN IP4 XXXXXXXXXX
t=0 0
c=IN IP4 XXXXXXXXXX
a=fmtp:101 0-16
a=ptime:20
002391: Feb 28 11:17:14.246: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP XXXXXXXXXX:5060;received=XXXXXXXXXX;rport=65168;branch=z9hG4bK1B7D4F
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25656 req_src_ip=XXXXXXXXXX req_src_port=65168 in_uri=sip:18002336111@slingshot.vtnoc.net:5060 out_uri=sip:18002336111@slings"
002392: Feb 28 11:17:14.278: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25656 req_src_ip=XXXXXXXXXX req_src_port=65168 in_uri=sip:18002336111@slingshot.vtnoc.net:5060 out_uri=sip:+18002336111@216.2"
002393: Feb 28 11:17:15.206: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:+18002336111@slingshot.vtnoc.net>;tag=SDsa1fc99-14c031a8+1+5946032b+779d37eb
CSeq: 102 INVITE
Record-Route: <sip:216.246.37.202;lr;ftag=EE182A8-1CDA>
Record-Route: <sip:198.8.63.63;lr;ftag=EE182A8-1CDA;vsf=AAAAABoBCXJGWFtXVkRaWzRdGh0ACBBGARFadnRub2MubmV0>
Server: DC-SIP/2.0
Contact: <sip:8002336111@65.98.236.46:5060;transport=udp>
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
o=- 3634139836 3634139843 IN IP4 65.98.236.46
s=-
c=IN IP4 65.98.236.46
t=0 0
m=audio 20528 RTP/AVP 0 101
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002394: Feb 28 11:17:15.206: //313/397FB52581C3/CCAPI/cc_api_call_cut_progress:
Interface=0x3EBE699C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
Cause Value=0
002395: Feb 28 11:17:15.206: //313/397FB52581C3/CCAPI/cc_api_call_cut_progress:
Call Entry(Responsed=TRUE)
002396: Feb 28 11:17:15.206: //312/397FB52581C3/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
002397: Feb 28 11:17:15.206: //312/397FB52581C3/CCAPI/ccCallCutProgress:
002398: Feb 28 11:17:15.206: //312/397FB52581C3/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
002399: Feb 28 11:17:15.206: //312/397FB52581C3/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x138, gcid=397FB525-BEB511E4-81C3ECAB-8E7838B0, tag=0x0)
002400: Feb 28 11:17:15.206: //313/397FB52581C3/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x139, gcid=397FB525-BEB511E4-81C3ECAB-8E7838B0, tag=0x0)
002401: Feb 28 11:17:15.206: //312/397FB52581C3/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFF, Call Id1=312, Call Id2=313, Tag=0x0
002402: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_bridge_done:
Conference Id=0x10, Source Interface=0x2416DF80, Source Call Id=312,
Destination Call Id=313, Disposition=0x0, Tag=0xFFFFFFFF
002403: Feb 28 11:17:15.210: //313/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002404: Feb 28 11:17:15.210: cc_api_get_xcode_stream : 4982
002405: Feb 28 11:17:15.210: //313/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002406: Feb 28 11:17:15.210: cc_api_get_xcode_stream : 4982
002407: Feb 28 11:17:15.210: //313/397FB52581C3/CCAPI/cc_api_bridge_done:
Conference Id=0x10, Source Interface=0x3EBE699C, Source Call Id=313,
Destination Call Id=312, Disposition=0x0, Tag=0x0
002408: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_generic_bridge_done:
002409: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x10, Destination Call Id=313)
002410: Feb 28 11:17:15.210: //313/397FB52581C3/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x10, Destination Call Id=312)
002411: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/ccConferenceCreate:
002412: Feb 28 11:17:15.210: confID:0x10; callEntry1 callID1:0x138, type:6; callEntry2 callID2:0x139, type:3
002413: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EBE699C, Destination Call Id=313, Source Call Id=312,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=20, Signal Type=3)
002414: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
002415: Feb 28 11:17:15.210: //313/397FB52581C3/CCAPI/cc_api_caps_ind:
Destination Interface=0x2416DF80, Destination Call Id=312, Source Call Id=313,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
002416: Feb 28 11:17:15.210: //313/397FB52581C3/CCAPI/cc_api_caps_ind:
002417: Feb 28 11:17:15.210: //313/397FB52581C3/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=7822)
002418: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_caps_ack:
002419: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/ccCallFeature:
Feature Type=25, Call Id=312
002420: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/ccCallFeature:
002421: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_voice_mode_event:
Call Id=312
002422: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x2455CB1C)
002423: Feb 28 11:17:15.210: //312/397FB52581C3/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x10, Call Id1=312, Call Id2=313
002424: Feb 28 11:17:15.214: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:8002336111@65.98.236.46:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXX:5060;branch=z9hG4bK1B82527
To: <sip:18002336111@slingshot.vtnoc.net>;tag=SDsa1fc99-14c031a8+1+5946032b+779d37eb
CSeq: 103 PRACK
RAck: 601214472 102 INVITE
Route: <sip:198.8.63.63;lr;ftag=EE182A8-1CDA;vsf=AAAAABoBCXJGWFtXVkRaWzRdGh0ACBBGARFadnRub2MubmV0>,<sip:216.246.37.202;lr;ftag=EE182A8-1CDA>
Proxy-Authorization: Digest username="19255551212",realm="slingshot.vtnoc.net",uri="sip:8002336111@65.98.236.46:5060;transport=udp",response="af74b6981bbdd11cbae1d6860f0e0e62",nonce="54f2
Max-Forwards: 70
Content-Length: 0
002425: Feb 28 11:17:15.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002426: Feb 28 11:17:15.710: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002427: Feb 28 11:17:16.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002428: Feb 28 11:17:16.742: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002429: Feb 28 11:17:18.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002430: Feb 28 11:17:18.750: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002431: Feb 28 11:17:22.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002432: Feb 28 11:17:22.798: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002433: Feb 28 11:17:26.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002434: Feb 28 11:17:30.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002435: Feb 28 11:17:30.798: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002436: Feb 28 11:17:34.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002437: Feb 28 11:17:38.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002438: Feb 28 11:17:42.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002439: Feb 28 11:17:46.706: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002440: Feb 28 11:17:46.842: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 601214472
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002441: Feb 28 11:17:47.902: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:+18002336111@slingshot.vtnoc.net>;tag=SDsa1fc99-14c01da8+1+e2f9003e+3186d2c2
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 477961899
Content-Length: 214
v=0
o=- 3634139868 3634139875 IN IP4 65.98.236.46
s=-
t=0 0
m=audio 20534 RTP/AVP 0 101
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002442: Feb 28 11:17:47.902: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP XXXXXXXXXX:5060;branch=z9hG4bK1B92548
To: <sip:18002336111@slingshot.vtnoc.net>;tag=SDsa1fc99-14c01da8+1+e2f9003e+3186d2c2
CSeq: 103 PRACK
RAck: 477961899 102 INVITE
Max-Forwards: 70
Content-Length: 0
002443: Feb 28 11:17:48.402: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002444: Feb 28 11:17:48.402: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 477961899
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002445: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x2416DF80, Call Id=312
002446: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
002447: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/ccConferenceDestroy:
Conference Id=0x10, Tag=0x0
002448: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/ccConferenceDestroy:
002449: Feb 28 11:17:49.278: confID:0x10; callEntry1 callID1:0x138, type:6; callEntry2 callID2:0x139, type:3
002450: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=313, Disposition=0x0, Tag=0x0
002451: Feb 28 11:17:49.278: //313/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002452: Feb 28 11:17:49.278: cc_api_get_xcode_stream : 4982
002453: Feb 28 11:17:49.278: //312/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002454: Feb 28 11:17:49.278: cc_api_get_xcode_stream : 4982
002455: Feb 28 11:17:49.278: //313/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002456: Feb 28 11:17:49.278: cc_api_get_xcode_stream : 4982
002457: Feb 28 11:17:49.278: //313/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002458: Feb 28 11:17:49.278: cc_api_get_xcode_stream : 4982
002459: Feb 28 11:17:49.278: //313/397FB52581C3/CCAPI/cc_api_bridge_drop_done:
002460: Feb 28 11:17:49.278: //312/397FB52581C3/CCAPI/cc_generic_bridge_done:
002461: Feb 28 11:17:49.282: //313/397FB52581C3/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002462: Feb 28 11:17:49.282: //313/397FB52581C3/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
002463: Feb 28 11:17:49.282: //312/397FB52581C3/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
002464: Feb 28 11:17:49.282: //312/397FB52581C3/CCAPI/ccCallDisconnect:
002465: Feb 28 11:17:49.282: //312/397FB52581C3/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
002466: Feb 28 11:17:49.282: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:18002336111@slingshot.vtnoc.net:5060 SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1425151069
Reason: Q.850;cause=16
Content-Length: 0
002467: Feb 28 11:17:49.286: //312/397FB52581C3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2416DF80, Tag=0x0, Call Id=312,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
002468: Feb 28 11:17:49.286: //312/397FB52581C3/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
002469: Feb 28 11:17:49.286: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002470: Feb 28 11:17:49.286: :cc_free_feature_vsa freeing 24D21C70
002471: Feb 28 11:17:49.286: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002472: Feb 28 11:17:49.286: vsacount in free is 1
002473: Feb 28 11:17:49.310: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 canceling
To: <sip:18002336111@slingshot.vtnoc.net>;tag=0e617f3419f967f79f34a07c459caad4-0182
CSeq: 102 CANCEL
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25651 req_src_ip=XXXXXXXXXX req_src_port=65168 in_uri=sip:18002336111@slingshot.vtnoc.net:5060 out_uri=sip:18002336111@slings"
002474: Feb 28 11:17:49.310: //313/397FB52581C3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EBE699C, Tag=0x0, Call Id=313,
002475: Feb 28 11:17:49.310: //313/397FB52581C3/CCAPI/cc_api_call_disconnect_done:
002476: Feb 28 11:17:49.310: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002477: Feb 28 11:17:49.310: :cc_free_feature_vsa freeing 24D21D50
002478: Feb 28 11:17:49.310: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002479: Feb 28 11:17:49.310: vsacount in free is 0
002480: Feb 28 11:17:49.402: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002481: Feb 28 11:17:49.418: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 477961899
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002482: Feb 28 11:17:51.402: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002483: Feb 28 11:17:51.438: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
Server: DC-SIP/2.0
Require: 100rel
RSeq: 477961899
Content-Length: 214
v=0
s=-
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
002484: Feb 28 11:17:55.402: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP XXXXXXXX;5060;branch=z9hG4bK1B92548
CSeq: 103 PRACK
Max-Forwards: 70
Content-Length: 0
002485: Feb 28 11:17:55.438: //313/397FB52581C3/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP XXXXXXXX:5060;received=XXXXXXXX;rport=65168;branch=z9hG4bK1B7D4F
CSeq: 102 INVITE
02-28-2015 12:02 PM
Upon further investigation, it seems ALL calls are dropping after about 30 or so seconds, not just voice recognition systems. Thanks
02-28-2015 12:41 PM
FG
02-28-2015 03:18 PM
Francisco - "no ip address trusted authenticate" had no affect on the call duration before the call drops. Further to this, I can see the SIP lines are in fact authenticated and bound (I think - you are the expert, so I'll defer to your expertise).
ISGNAV01#show sip-ua register status
Line peer expires(sec) reg survival P-Associ-URI
100 20004 2446 yes normal
101 20005 2460 yes normal
ISGNAV01#show sip-ua connections udp detail
Total active connections : 1
No. of send failures : 1
No. of remote closures : 0
No. of conn. failures : 0
No. of inactive conn. ageouts : 103
---------Printing Detailed Connection Report---------
Note:
** Tuples with no matching socket entry
- Do 'clear sip <tcp[tls]/udp> conn t ipv4:<addr>:<port>'
to overcome this error condition
++ Tuples with mismatched address/port entry
- Do 'clear sip <tcp[tls]/udp> conn t ipv4:<addr>:<port> id <connid>'
Remote-Agent:198.8.63.63, Connections-Count:1
Remote-Port Conn-Id Conn-State WriteQ-Size Local-Address
5060 2 Established 0 -
-------------- SIP Transport Layer Listen Sockets ---------------
Conn-Id Local-Address
0 [0.0.0.0]:5060:
The viatalk configuration is detailed in a few places and I try to mirror that in my configuration. See this:
https://support.viatalk.com/index.php?_a=knowledgebase&_j=questiondetails&_i=125
https://rolande.wordpress.com/2007/12/09/configuring-a-cisco3725-with-callmanager-express-4-0/
and here:
https://tekcert.com/blog/2011/02/03/cme-configuration-example-sip-trunks-viatalk-and-voipms
Do you see any differences in my configuration? Also - can you tell me which required ports need to be opened for ACLs?
And FYI, I have also opened a ticket to viatalk to examine the configuration and to provide additional support.
02-28-2015 04:38 PM
k.scholtens,
Thank you for the additional info. The "no ip address authenticate" was just to make sure you were not refusing incoming calls, it will have no effect on the duration issue. The registration does indeed look correct.
I have experienced call disconnects after some time as well, I have usually resolved this working with my provider on tuning the sip session timers, however, this definitely looks different. Looking at the CCSIP messages closer, after authenticating, the carrier sends you a "183 session in progress" message, negotating g711ulaw and rtp-nte for dtmf. For some reason, you keep responding with PRACKS. It looks like you keep sending the authentication information while the carrier has already established the call, and then you send a CANCEL message to end the call.
I will review the documentation and your config a little closer and get back to you with some more info.
FG
03-01-2015 11:17 AM
Thank you Francisco.
Per some of the recommendations from the sites I listed above, especially this one:
I tried changing up the dialing pattern that appears to be matching as shown below. This too had little to no affect. Calls continue to drop after 30 - 45 seconds, then simply redial the number.
UPDATE: I've also tried testing adding "no vad" back and removing "sip-notify" from dial-peer 4 and this too had no affect.
I eagerly look forward to your response.
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip <-------- THIS ONE
dtmf-relay sip-notify rtp-nte
codec g711ulaw
codec g711ulaw
03-01-2015 11:50 AM
voice service voip
sip
FG
03-02-2015 09:07 AM
Oh! I think you were on the right track...
I am testing now and will let you know later, but initial results are positive!!!
I found this post in:
The solution was to disable PRACK. To do this in Cisco CME:
2821-rtr(config)#voice service voip
2821-rtr(conf-voi-serv)#sip
2821-rtr(conf-serv-sip)# rel1xx ?
disable Disables reliable-provisional responses
require Requires reliable-provisional responses
supported Supports reliable-provisional responses
2821-rtr(conf-serv-sip)#rel1xx disable
03-02-2015 09:31 AM
Sounds good.
Every scenario is different depending on ISP requirements, let me know how it works.
FG
