06-06-2016 01:39 PM - edited 03-17-2019 07:09 AM
We've upgraded our Cisco phones to new Cisco 8851 phonesets. The 5 buttons left of the screen are easily programmable, but I was hoping to program a few of the unused buttons on the right hand side of the screen. Does anyone know if these are programmable, and if so the process of doing so?
-Darren
06-06-2016 01:55 PM
Hi Darren,
8851 comes only with 5 programble line keys left hand side and the button which you see on right hand side are session buttons .These are used to answer a call or resume a held call or display missed calls etc.
http://www.cisco.com/assets/cdc_content_elements/flash/voice/ipconferencephone8800/index.htmlHi
06-06-2016 02:07 PM
Thanks for the reply Deepak,
And there are not creative ways to program a few of these unused session keys in CUCM that you are aware of?
06-06-2016 02:13 PM
That is a good question . I dont think we can, as each session button is asscoiated with a call .So if a call comes in you can use session button to answer or hold or to retrieve.
I haven't tried it though so if find something ,please update here.
Deepak Mehta
06-06-2016 07:18 PM
Darren, if you really need to use more than 5 line buttons then you will need to use a KEM and do it that way. Refer Programmable feature buttons and Session of below document for more:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series.pdf
Deepak
06-06-2016 01:58 PM
no, we can only configure up-to five programmable lines as the 8800 series phones offers only five programmable line keys below is the reference document for the same.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731667.html
Also the below data sheet demo video confirms the same.
http://www.cisco.com/c/en/us/products/collaboration-endpoints/ip-phone-8851/index.html
06-07-2016 06:12 AM
Hi Darren,
In the latest firmware update for the 8800 series phones, 11.5(1), a new feature called Enhanced Line Mode was added. This allows you to use the 5 "session" buttons as line keys. The features on the phone are limited when this is enabled as documented here in the release notes.
I hope this helps.
-Spencer
06-07-2017 08:27 PM
Did you get this resolved? I had issue and I needed to upgrade my cluster to 11.5 and then the enhanced Line Mode Appears magically on the 8800. It is second from bottom. I had a hard time to get a straight answer and a document that says you need CUCM 11,5 min.
Hope you have it fixed but just in case I thought I would add my two cents
03-07-2019 09:30 AM
I have 11.0 and at the bottom of the initial phone configuration page there is a drop down for session/enhanced mode. You will also need to program a button template to go along w/that or I believe they just become Spd DL's by default. I am trying to add a hunt login key to the right side with the phone still in session mode as to not burn a line key.
