PSTN calls are not going through Route List
Running UCM 9.1.x cluster at Central location.
Branch location is deployed with two SRST Routers with E1 PRI terminated on each
Gateway.
we are facing one problem.PSTN calls are not going through Primary E1 PRI which is pointed to the Route List. Calls are going through
Secondary PRI,even Primary PRI is having higher priority in the Route Group. The Incoming calls are coming through Primary PRI.
In debug also it is not showing   calls are  hitting to the Voice gateway where the Primary PRI is terminated.
In SRST fail over calls are going through primary PRI.
If i configure the route pattern and pointing to the PRI interface of the Primary PRI, the calls are routing through Primary PRI.
Due this to  PRI failover is not working.
Please help me out!!!
Krishna
Ayodeji Okanlawon
Krish,
Try and remove the PRI from the route group, re-add it, then save , then reset the route list. For some reason the RL when searching through the route group, is not seeing the PRI
This seem to be happening a lot on CUCM9.X as reported by Cisco in this thread..
https://supportforums.cisco.com/message/3927483#3927483
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi aokanlawon,
Thanks for your reply.
I tried , but still not working !!
Krishna
