07-05-2008 03:17 AM - edited 03-15-2019 11:45 AM
Hi all,
My PSTN phone disconnects after 25 seconds when I put it on hold from my MGCP branch router.
I don't know what other information to provide here. Please ask questions.
Thanks in advance for helping out.
Solved! Go to Solution.
07-05-2008 10:57 AM
Hi Shailendra,
Please try the following command on your gateway.
no mgcp timer receive-rtcp
From this good doc;
Hope this helps!
Rob
07-05-2008 05:01 AM
what do you mean by your pstn phone..?? Do you mean a call to the pstn or a call from the pstn..if this is it then do the following..
on your router turn on debugging..type the following in privilige mode...
debug isdn q931
term mon
place a test call and send the output of the debug
07-06-2008 06:15 AM
Hi thanks for taking the time to reply,
The call in or out to the PSTN was having the same problem.
The issue is resolved by the foll command:
as suggested by Rob.
07-05-2008 10:57 AM
Hi Shailendra,
From this good doc;
Hope this helps!
Rob
07-06-2008 06:17 AM
Hi Rob,
Thanks. Spot on.
Did the job first time.
