PSTN Phone disconnects after on-hold for 25 seconds
ShailendraK
Hi all,
My PSTN phone disconnects after 25 seconds when I put it on hold from my MGCP branch router.
I don't know what other information to provide here. Please ask questions.
Thanks in advance for helping out.
Rob Huffman
Hi Shailendra,
Please try the following command on your gateway.
no mgcp timer receive-rtcp
From this good doc;
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f2e.html#wp1370227
Hope this helps!
Rob
Ayodeji Okanlawon
what do you mean by your pstn phone..?? Do you mean a call to the pstn or a call from the pstn..if this is it then do the following..
on your router turn on debugging..type the following in privilige mode...
debug isdn q931
term mon
place a test call and send the output of the debug
Please rate all useful posts
Hi thanks for taking the time to reply,
The call in or out to the PSTN was having the same problem.
The issue is resolved by the foll command:
as suggested by Rob.
Rob Huffman
Hi Shailendra,
From this good doc;
Hope this helps!
Rob
Hi Rob,
Thanks. Spot on.
Did the job first time.
