Publisher is down which write access subscriber have ???
vishal shinde
any one have idea.....??
5 Replies 5
Gordon Ross
Level 9
Level 9
None.
Only the publisher can make changes to the DB. (Later versions of CUCM allow small changes like diverts withouth the publisher.)
GTG
Please rate all helpful posts.
barry
Level 7
Level 7
This information is slightly old (for version 6.x) but I think it is still valid:
in 6.x with publisher offline there is a new feature called 'user facing
features' that should allow normal user activities. user facing
features include: in 6.x with publisher offline there is a new feature called 'user facing
features include:
1. Call Forward All (CFA)
2. Message Waiting Indication (MWI)
3. Privacy Enable/Disable
4. Do Not Disturb Enable/Disable (DND)
5. Extension Mobility Login (EM)
6. Monitor (for future use, currently no updates at the user level)
7. Hunt Group Logout
8. Device Mobility
9. CTI CAPF status for end users and application users
10. Credential authentication
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
Robert Thomas
Level 7
Level 7
Basically you can only perform changes on the Database through the PUB. The database for the SUB is a read only replica used by the ccm and tftp component. The cmadmin component on the SUB actually points to the PUB DB.
You should try to focus your efforts on restoring the PUB, sometimea it comes in handy to have a PUB ;)
p.mcgowan
Level 3
Level 3
the followng document details how replication works on a CUCM server and what write access a sub has in the event of a pub failure, it is an excellent document for explaining and troubleshooting replication issues on a CUCM cluster
https://supportforums.cisco.com/docs/DOC-13672
Please rate helpful posts
vishal shinde
Thanks guys for your reply......
