IP Telephony and Phones
watch here Journey banner_1
Labels
I have installed a fresh install of Unity Connection 8.6(2) and had set up a voice directory handler that was working fine.CTI Routepoint with a DN with CFWD all to Voicemail then the Mailbox has the Standard Greeting set to the VoiceEnabledDirectory...
ian-lewis by Level 1
  • 1996 Views
  • 11 replies
We are offering HCS based solution from data center for a site with 20,000 end points.For local survivability, Maximum phones supported by SRST are 1500, should we install multiple SRST 's or there is a better solution (supported with HCS)           ...
How can we tell if the dial peer configured is inbound dial peer or out bound dial peer?  I mean  We don't use any word explicitly do define a dial peer as inbound or outbound. Rather  a dial peer direction i.e inbound or outbound is determined by if...
sarahr202 by Level 5
  • 9417 Views
  • 9 replies
Hello i wanna change my CUCM subnet mask, running on VMWARE, i know that i will need to rehost the license for new license mac. #•Time zone #•NTP server 1 (or "none") #•NIC speed (or "auto") #•Hostname #•IP Address (or "dhcp") #•IP Mask (or "dhcp") #...
