08-21-2008 03:49 AM - edited 03-15-2019 12:45 PM
One of our Device Pools contains over 2000 devices. I will be scheduling a push of the newer SCCP signed phone load P00308000900 (cmterm-7949-7960.8-0-9.exe) over a coming weekend.
Trouble is - the Device Pool contains a LOT of devices :o(
What impact (if any) is this likely to cause? I'm assuming that it will just take a while for all the devices to pull the new xml file for the App Load from the Publisher/Subscriber they home to.
We run CCM 3.3(3) on App Load P00303030401 at present. It will be our 7960's that get the upgrade to P00308000900. Tests to a few devices have been successful - but when 2000+ get told to restart en-masse, i think our CCM cluster might have a heart attack! :o)
08-21-2008 04:28 AM
Hi Andy,
When we push a new Firmware to large numbers of IP Phones we do them 50 to 100 at a time so as not to run into the issues you are worried about.
Via ccmadmin if you go to;
Device>Phone>Search by Device Type>7960 and all the 7960's will be available (check 50 per page). Then Select-All checkbox and reset. You just go page by page and reset all 50. When I'm really living on the edge I'll reset two pages at a time ;-) This way you can also see if any don't come back to life after the upgrade.
Hope this helps!
Rob
09-05-2008 12:24 PM
Just by way of an update - im sat here at 9pm (UK time) slowly resetting 47 pages of 7960 IP phones - set at 50 phones per page!
Looks like it takes about 5 mins to reset 50 at a time. Refreshing the page shows them slowly moving from 'not registered' to having registered with the Publisher.
Thanks for the tip Rob!
09-06-2008 10:03 AM
Hey Andy,
You are most welcome my friend! Thanks for posting back with your results. +5 points for this kindness. This is a slow process but at least it's safe ;-)
Take care,
Rob
