How to Verify and Troubleshoot the Functionality of the PVDM3 Cards on Cisco Voice Gateways
Use the following commands in global configuration mode to verify and troubleshoot the functionality of the PVDM2 and PVDM3 modules in your Cisco voice gateway.
SUMMARY STEPS
1. show platform hw-module-power
1. show voice call slot / port
2. show voice dsp group all
3. show voice dsp sorted-list
4. show voice dsp capabilities slot number dsp number
5. show voice dsp group slot number
6. show voice dsp statistics device
7. show voice dsp statistics tx-rx
8. show voice dsp statistics ack
9. debug voice dsp crash-dump
DETAILED STEPS
Step 1 show platform hw-module-power
NoteEffective with Cisco IOS Releases 15.1(1)T and 15.0.1M(2), the Effective with Cisco IOS Releases 15.1(1)T and 15.0.1M(2), the hw-module energywise level command is not available in Cisco IOS software. For more information, see the Cisco 3900 Series, 2900 Series, and 1900 Series Software Configuration Guide.
Use this command to display power settings of PVDM3 service modules, for example:
Router# show platform hw-module-power Levels supported 0x441 : SHUT FRUGAL FULL CURRENT level : 10 (FULL) Previous level : 10 (FULL) Transitions : Successful Unsuccessful Levels supported 0x441 : SHUT FRUGAL FULL CURRENT level : 10 (FULL) Previous level : 0 (SHUT) Transitions : Successful Unsuccessful Levels supported 0x441 : SHUT FRUGAL FULL CURRENT level : 10 (FULL) Previous level : 10 (FULL) Transitions : Successful Unsuccessful Step 2 show voice call slot / port
Note If you are connected using a Telnet session, you must enter the terminal monitor command before the show voice call command to see console messages. This step is not necessary if you are connected to the console port.
Use this command to display statistics for voice calls on a specific slot and port, for example:
Router# show voice call 0/1/1:23 vtsp level 0 state = S_CONNECT callid 0x0011 B01 state S_TSP_CONNECT clld 4085001112 cllg 4085001112 vtsp level 0 state = S_CONNECT callid 0x0012 B02 state S_TSP_CONNECT clld 4085001112 cllg 4085001112 Step 3 show voice dsp group all
Use this command to display information for each DSP group, for example:
Router# show voice dsp group all State: UP, firmware: 26.0.135 Max signal/voice channel: 43/43 num_of_sig_chnls_allocated: 35 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 630, reserved credits: 0 Signaling channels allocated: 35 Voice channels allocated: 1 Credits used (rounded-up): 15 Ch01: voice port: 0/1/1:23.2, codec: g711alaw, credits allocated: 15 State: UP, firmware: 26.0.135 Max signal/voice channel: 43/43 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 645, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.135 Max signal/voice channel: 42/43 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 645, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.135 Max signal/voice channel: 43/43 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 645, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.135 Max signal/voice channel: 43/43 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 645, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.135 Max signal/voice channel: 42/43 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 645, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.135 Max signal/voice channel: 32/32 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 465, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 1 Credits used (rounded-up): 15 Ch01: voice port: 0/1/1:23.1, codec: g711alaw, credits allocated: 15 State: UP, firmware: 26.0.133 Max signal/voice channel: 16/16 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 240, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.133 Max signal/voice channel: 16/16 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 240, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.133 Max signal/voice channel: 16/16 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 240, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 State: UP, firmware: 26.0.133 Max signal/voice channel: 16/16 num_of_sig_chnls_allocated: 0 Transcoding channels allocated: 0 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 240, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Credits used (rounded-up): 0 This command is not applicable to slot 3 This command is not applicable to slot 4 2 DSP resource allocation failure Step 4 show voice dsp sorted-list
Use this command to display the hunt order in which DSPs are utilized for particular services (in this example, voice, conferencing, and transcoding are shown for slot 0):
Router# show voice dsp sorted-list slot 0 DSP id selection list for different service for Card 0: ======================================================== Voice :01,02,03,04,05,06,07 Conf :07,06,05,04,03,02,01 Xcode :01,02,03,04,05,06,07 Step 5 show voice dsp capabilities slot number dsp number
Use this command to display capabilities data for a particular DSP on a particular slot (in this example, DSP 2 on slot 0):
Router# show voice dsp capabilities slot 0 dsp 2 Card 0 DSP id 2 Capabilities: Credits 645 , G711Credits 15, HC Credits 32, MC Credits 20, FC Channel 43, HC Channel 20, MC Channel 32, Conference 8-party credits: G711 58 , G729 107, G722 129, ILBC 215 Sec LC Xcode 24, Sec HC Xcode 64, Sec MC Xcode 35, Sec G729 conf 161, Sec G722 conf 215, Sec ILBC conf 322, Max Conference Parties per DSP: G711 88, G729 48, G722 40, ILBC 24, Sec G711 56, Sec G729 32, g711perdsp = 43, g726perdsp = 32, g729perdsp = 20, g729aperdsp = 32, g723perdsp = 20, g728perdsp = 20, g723perdsp = 20, gsmperdsp = 32, gsmefrperdsp = 20, gsmamrnbperdsp = 20, ilbcperdsp = 20, modemrelayperdsp = 20 g72264Perdsp = 32, h324perdsp = 20, m_f_thruperdsp = 43, faxrelayperdsp = 32, maxchperdsp = 43, minchperdsp = 20, srtp_maxchperdsp = 27, srtp_minchperdsp = 14, faxrelay_srtp_perdsp = 14, g711_srtp_perdsp = 27, g729_srtp_perdsp = 14, g729a_srtp_perdsp = 24, Step 6 show voice dsp group slot number
Use this command to display the current status or selective statistics of DSP voice channels for a specific DSP group. For example:
Router# show voice dsp group slot 0 State: UP, firmware: 8.4.0 Max signal/voice channel: 16/16 Group: FLEX_GROUP_VOICE, complexity: FLEX Shared credits: 240, reserved credits: 0 Signaling channels allocated: 0 Voice channels allocated: 0 Oversubscription: can either be an indicator or a counter Step 7 show voice dsp statistics device
Use this command to display DSP voice statistics for the device:
Router# show voice dsp statistics device DEVICE DSP CURR AI/RST/WDT ACK MAC TX/RX PACK KEEPALIVE ID ID STATE COUNT FAIL ADDRESS COUNT TX/RX/SKP ======= === ===== ========= ===== ============= ================= ============= 0/0/0 1 1 0/0/0 0 00fa.ce25.0000 51645919/37972871 29875/29875/0 0/0/0 2 1 0/0/0 0 00fa.ce25.0000 51645919/37972871 29875/29875/0 0/0/0 3 1 0/0/0 0 00fa.ce25.0000 51645919/37972871 29875/29875/0 0/0/1 4 1 0/0/0 0 00fa.ce25.0001 28355309/20859980 29875/29875/0 0/0/1 5 1 0/0/0 0 00fa.ce25.0001 28355309/20859980 29875/29875/0 0/0/1 6 1 0/0/0 0 00fa.ce25.0001 28355309/20859980 29875/29875/0 Step 8 show voice dsp statistics tx-rx
Use this command to display transmitted and received packet counts for the device:
Router# show voice dsp statistics tx-rx Device and Port Statistics: PVDM-0 ------------------------------------ 8903 input packets at port, 15374 output packets at port 6853 packets from device, 11793 packets to device 0 Ctrl & 0 Media out of sequence packets, 0 packets drop 0 input error packets, 0 output error packets 0 resource errors packets, 0 gaints 2048 packets from device, 3579 packets to device 0 Ctrl & 0 Media out of sequence packets, 0 packets drop 0 input error packets, 0 output error packets 0 resource errors packets, 0 gaints Device and Port Statistics: PVDM-1 ------------------------------------ 29083 input packets at port, 32627 output packets at port 29081 packets from device, 32627 packets to device 0 Ctrl & 0 Media out of sequence packets, 0 packets drop 0 input error packets, 0 output error packets 0 resource errors packets, 0 gaints BP throttle change count 0, Current throttle flag 0 TX messages at congestion count 0 Step 9 show voice dsp statistics ack
Use this command to display ACK statistics for the device:
Router# show voice dsp statistics ack DSP ACK RETRY TOTAL WAITING ID DEPTH COUNT RETRANSMITTION FOR ACK === ===== ====== ============== ======== Step 10 debug voice dsp crash-dump
Use this command to display debugging information for the crash dump feature (for detailed information about this, see the section Voice DSP Crash Dump File Analysis in Cisco IOS Voice Troubleshooting and Monitoring Guide ):
Router# debug voice dsp crash-dump keepalives
Yosh
