07-06-2012 12:37 AM - edited 03-16-2019 12:03 PM
We have a QSIG link between a 3845 and Avaya PBX. When we try calling across it (IP to Analog), the phone rings but there is no audio stream when going off hook.
Any suggestions on what could cause this type of behaviour?
config
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-31
description E1 controller card for QSIG
interface Serial0/2/0:15
description QSIG interface towards Avaya PBX
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn contiguous-bchan
no cdp enable
dial-peer voice 9000 pots
description <=== QSIG trunk test ===>
destination-pattern 777....
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
fax rate disable
port 0/2/0:15
forward-digits 4
On CUCM there is a route pattern 777xxxx towards the gateway (H323) with no discard digits
Solved! Go to Solution.
07-10-2012 01:41 AM
I don't recall having to set 'isdn contiguous-bchan' before.
From the docs it looks like it might adjust the channel usage so the first call goes out 30 rather than 31? I'm not sure to be honest, but since it's working one direction and not the other (and I presume you have verified the call lands on a phone with someone answering it at the other end) I'd try it without - it might require a similar setting on the far end.
Try taking that out and shut/no shutting it, or try setting the channel selection order to ascending.
Aaron
07-10-2012 12:21 AM
I do not know what the Problem ist, but i can suggest you a document from Cisco which handles an similar configuration.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/467019.pdf
07-10-2012 12:28 AM
HI
If you do not find any solution. Consider change gateway to MGCp and configured as shown below.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/537421.pdf
Ronak Patel
Rate helpful posts.
07-10-2012 12:33 AM
I know but we can not change it to MGCP
07-10-2012 01:03 AM
1) Does it work when calling in the other direction?
2) When you make the call from the IP phone, if you view the call stats (e.g. press ? quickly twice when on the call on a 794x/6x handset) do you see the 'rx' packets increasing?
Aaron
07-10-2012 01:05 AM
Hi Aaron
yes, for some strange reason it started to work from Avaya towards Cisco 5I can confirm nothing changed on the Cisco end)
in both directions we see RTP stream on the IP phone and they increment
Koen
07-10-2012 01:41 AM
Aaron
07-10-2012 01:43 AM
Thanks Aaron
I will change that line and make a test call, I have a TAC case open for it as well so in a way I want to make as less changes to the config as possible :-)
Koen
07-10-2012 02:00 AM
Hi Aaron
that worked removed it and I could hear the other party
Thank you
Koen
07-10-2012 02:09 AM
Great news.
Principal Engineer at Logicalis UK
Please rate helpful posts...
