Query on Call Forward and FAC
S N
Experts,
I have a query regarding the use of FAC in call forward scenario.
CUCM 8.5 version.
We are setting up a Call forward to the user's mobile number, if the extension is not pick within certain rings.
We have a route pattern with FAC enabled and the user mobile number needs to pass through this FAC enabled route pattern.
Is there a way in CUCM to send FAC along with the call forward number.
Sathya
Jaime Valencia
No, you need to create a RP without FAC for those calls.
java
if this helps, please rate
Thank you.
Adarsh Chauhan
Level 3
Level 3
Hi Sathya,
This is a limitation. you cannot use the the RP with FAC to route forwarded calls.
FAC Restriction.
I would suggest to make a copy of the Route Pattern with FAC disabled and put it in a different partition.
Apply a CSS on the CFA section which has access to this new Route pattern and that should serve the purpose.
Please rate if helpful.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
