02-09-2009 02:49 PM - edited 03-15-2019 04:05 PM
I've been testing a 7925G in our environment and I must say it's a great phone. The only thing I find unusual is that it doesn't appear as a registered device in CUCM 6. Does anyone know if this is normal?
- Shikamaru
02-09-2009 08:50 PM
7925 was introduced after CM 6 was already out, make sure you have the latest device pack installed that supports 7925.
HTH,
Chris
02-09-2009 09:02 PM
It's installed and working, so the device pack has already been installed (naturally). Have you noticed the same peculiarity? I wonder if I did any wrong.
-Shikamaru
02-09-2009 09:03 PM
I recall a bug specifically on CM 6.0 that had to do with devices not showing registration status. Perhaps you are running into that bug.
Chris
02-09-2009 09:15 PM
Okay, that helps a bit. I thought I was imagining things. Thanks, Chris.
- Shikamaru
