Question about the 7925G
shikamarunara
Level 4
Level 4
I've been testing a 7925G in our environment and I must say it's a great phone. The only thing I find unusual is that it doesn't appear as a registered device in CUCM 6. Does anyone know if this is normal?
- Shikamaru
Chris Deren
7925 was introduced after CM 6 was already out, make sure you have the latest device pack installed that supports 7925.
HTH,
Chris
It's installed and working, so the device pack has already been installed (naturally). Have you noticed the same peculiarity? I wonder if I did any wrong.
-Shikamaru
I recall a bug specifically on CM 6.0 that had to do with devices not showing registration status. Perhaps you are running into that bug.
Chris
Okay, that helps a bit. I thought I was imagining things. Thanks, Chris.
- Shikamaru
