06-13-2017 12:29 PM - edited 03-17-2019 10:33 AM
I haven't done voice in a while. Now I have been asked to replace some routers that we have in the field.
Do I need to order the voice bundle for the 4321 ISR, with a PVDM, if I'm only going to have one voip dial peer?
Scott
Solved! Go to Solution.
06-13-2017 01:25 PM
If it has a dial-peer than means it's a Cisco voice GW or CUBE. Any version of IOS with proper UC license allows for building dial-peers, the key here is the UC license.
06-13-2017 01:08 PM
It depends on what the voice GW you are replacing is doing. If you can share "show run", "sh diagnostics", "sh inventory" we can provide further guidance.
06-13-2017 01:22 PM
Thanks Chris,
I am not replacing a voice gateway. I am replacing a branch router that has only one voip dial-peer.
What version of the IOS do I need for dial-peer?
Scott
06-13-2017 01:25 PM
