Question about voice gateway
scottsassin
I haven't done voice in a while. Now I have been asked to replace some routers that we have in the field.
Do I need to order the voice bundle for the 4321 ISR, with a PVDM, if I'm only going to have one voip dial peer?
Scott
If it has a dial-peer than means it's a Cisco voice GW or CUBE. Any version of IOS with proper UC license allows for building dial-peers, the key here is the UC license.
Chris Deren
It depends on what the voice GW you are replacing is doing. If you can share "show run", "sh diagnostics", "sh inventory" we can provide further guidance.
Thanks Chris,
I am not replacing a voice gateway. I am replacing a branch router that has only one voip dial-peer.
What version of the IOS do I need for dial-peer?
Scott
