quick reference for css and partitions
carl_townshend
Hi all
Can anyone give me a quick reference on what we assign partitions to, and what we assign Call search spaces to, for example DN's, phones etc
Gordon Ross
Level 9
Level 9
Things get put into Partitions.
Calling Search Spaces say what partitions (hence things) you can see.
GTG
Please rate all helpful posts.
Easy way to think about this:
CSS - assigned to entities such as devices/gateway that participate dial numbers to were dialed and need to direct the call
Partition- assigned to any number that can be dialed
HTH,
Chris
Jaime Valencia
If you want a list of where a partition, and where a CSS can be configured, there isn't any
Sent from Cisco Technical Support Android App
java
if this helps, please rate
