05-12-2008 01:26 AM - edited 03-15-2019 10:35 AM
Hello friends,
Is it possible to configure, in CME, an extension to transfer the call NOAN after X seconds, but after the transfer, it rings on the destination extension and still rings in the original destination extension? (two phones ringing)?
Thank you,
Met.
Solved! Go to Solution.
05-12-2008 08:50 AM
Be aware, parallel ephone hunt works on in CME 4.3, as of today at the very first release.
For previous versions, you will have to CFNA to another DN that is shared/overlay.
05-12-2008 08:46 AM
In CME you can setup a 'simultaneous ring' line (using a hunt list/group/pilot)
Make the pilot, the number you want to ring after the NOAN and use the 'broadcast' distribution algorithm on the hunt list.
(or a shared line of the number that rings after the NOAN would work)
05-12-2008 08:50 AM
05-18-2008 09:07 AM
Thanks Paolo. Had to deal with shared lines (that raised another problem with login logout in hunt groups for bacd...but ill live with that i guess!).
Thanks again!
Met
05-12-2008 11:57 AM
oops....mistated the first edit...that was for CCM...sry :(
