12-16-2013 02:35 PM - edited 03-16-2019 08:53 PM
I have a question regarding ordering of user and extension on th ephone module, The only way I can see to do this is move the user down one by one.
Is there a quicker way to do this?
12-16-2013 02:39 PM
This is very simply with CLI, copy, adjust and paste.
Chris
12-16-2013 02:49 PM
Thanks for the reply, I am new to all this so I have been told we need to be able to adjust the extensions and users in the call manager web interface
12-16-2013 02:54 PM
You mentioned ephone so I assumed you have CallManager Express, what system and version do you have?
Chris
12-16-2013 03:23 PM
We are using the Cisco Unified CM administration, system version 8.6.2.21900
12-16-2013 03:26 PM
Then you can shift them one by one using "modify button items", or you can perform BAT update of the phones if you have a lot of them.
HTH,
Chris
12-16-2013 03:41 PM
Do you mean using this section to reorder
12-17-2013 03:02 PM
Correct.
HTH, please rate all useful posts!
Chris
