12-19-2012 11:06 AM - edited 03-16-2019 02:48 PM
Hello
I need to run the Recovery disk on CUCM 8.0.3.22900-5 and i have the recovery disk 8.0.3.20000-2 there is no problem correct ?
Leonardo Santana
Solved! Go to Solution.
12-19-2012 12:24 PM
Hi leonardo,
You can use that version. As long as both your CUCM and recovery disk major and minor versions are the same there is no problem. In this case it is 8.0.3.
HTH.
Harmit.
Sent from Cisco Technical Support Android App
12-19-2012 12:24 PM
Hi leonardo,
HTH.
Harmit.
12-20-2012 04:33 AM
Thanks Harmit
I run the recovery disk and the CUCM is fine now!
Leonardo Santana
