02-12-2020 10:10 PM
Hi all,
Need some advise whether cisco router (command) able to reduce background noise that appear on analog voice communication. Analog voice connection via fxs (routerA) to fxs (routerB).
02-13-2020 01:01 AM
You may find the following information useful for troubleshooting:
George
02-13-2020 12:37 PM
What kind of background noise are you getting?
If it's people talking and actual noises in the background, that has more to do with the microphone on the device that you're using.
If it's something like static, then it may be a faulty device or connection somewhere along the path between the device and the FXS port.
If you're hearing a humming noise, you may be running power parallel with your analog line.
02-14-2020 12:14 AM
