Regarding Jabber-config.xml file
geeta.kumari1
Hi All,
I want to understand when the jabber-config.xml file will be used by jabber client.
If the  jabber-config.xml is customized for 2 or 3 different site for certain attributes and uploaded to tftp server then where the configuration is to be done to use jabber-config-siteABC.xml for site ABC only and jabber-config-XYZ.xml for site XYZ only.
2 Accepted Solutions
Dennis Mink
in your CSF device's configuration there is a field called cisco support field, where you can define on a device individual basis, what config file to pull.
I have described this in the following post:
http://ciscoshizzle.blogspot.com.au/2015/02/how-to-obtain-jabber-configxml-file.html
you could bulk change your CSF device per ABC and XYZ site
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
That was a nice blog on customizing jabber-config especially the version change that eliminate the need for restarting tftp server. I wish I had known this much earlier.
Please rate all useful posts
7 Replies 7
Jaime Valencia
ALL jabber clients know to look for jabber-config.xml by default, and they will always try to look for it, UNLESS, you configure the individual devices to look for a group configuration .xml, as explained in the Jabber documentation.
java
if this helps, please rate
Hi All,
Thanks for your input on this topic.
Dennis, thanks for mentioning the version change option to avoid tftp server restart.
Hi Jaime,
Could you send me please the URL of Jabber dcumentation? I just have found feactures configuration.
Best regards,
If this helps, do not forget, rate!!
http://www.cisco.com/c/en/us/support/unified-communications/jabber-windows/tsd-products-support-series-home.html
java
Thank you so much Jaime.
Dennis Mink
Hi Dennis,
