05-07-2012 11:15 PM - edited 03-16-2019 11:02 AM
When configuring Region setting for new gateway, what should be the criteria to configure the "Modify Relationship to other Regions"
Should it be G.729 codec for voice or G711?
05-07-2012 11:21 PM
Gateway has nothing to choose. The region configuraiton is part of Device pool assigned to Gateway. So if Ip phone calling from same device pool, it will use G711 and if Ip phone calling another device pool it will use G729. Offcourse this has to be configured in Region configuration and not in gateway configuration.
Ronak Patel
Rate helpful posts.
05-07-2012 11:40 PM
If i have many regions in cucm...then i will select G.729 for all other regios and G.711 for itself?
05-07-2012 11:48 PM
hi
Yes you are correct.
Ronak Patel
Rate helpful posts by clicking stars below the answers.
05-08-2012 12:15 AM
This explains very nice the concept of regions in UCM: http://www.ciscopress.com/articles/article.asp?p=426635&seqNum=3
Typically, G.711 is used when BW is not an issue. For example, Phone A and Phone B are in the same site/campus and you assign them to a region "HQ". You should set G.711 for the HQ relationship with itself.
Typically, G.729 is used when BW is an issue. For example, Phone A in HQ region needs to talk with Phone C in a branch office (Phone C is assigned to "BR1" region). If BW is low, then you should set G.729 for the relationship between HQ and BR1.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
05-08-2012 12:53 AM
Thnaks for nice reply.
I have one more question regarding REGION.
What if i didnt select region to region codec settings? Does it really matter
05-08-2012 01:40 AM
THere are two system parameters:
Default Intraregion Max Audio Bit Rate : g711
Default Interregion Max Audio Bit Rate : g729
So if you have nothing set for a pair of regions it will use G729. Within any region it's G711 (or G722)
Principal Engineer at Logicalis UK
Please rate helpful posts...
