registering new phone, status failed
I got the same issue on yesterday, and TAC responded to ignore that fail status message, and it does not harm to 8831
13 Replies 13
ramiz.shaikh1
The phone is properly registered.
Firmware download is getting failed as the requested firmware may not be uploaded on the server.
Currently your phone is registered and has the firmware "sip8831.10-3-1SR3-5"
And it is requesting  "sip8831.10-3-1SR2-2" which is getting failed as this firmware may not be present on the server.
Please let me know if I understand your query correctly or elaborate more if I haven't.
1) is it because the phone is new and it came with newest firmware ?
2) how to make the firmware available on the server ?
3) would the new firmware affected the older phone ?
1) is it because the phone is new and it came with newest firmware ?  yes probably
2) how to make the firmware available on the server ? currently your phone running the latest firmware so there is no need to upload the previous version firmware for this phone.
Still below is the procedure to upload the firmware on cucm.
https://supportforums.cisco.com/t5/collaboration-voice-and-video/upgrade-downgrade-firmware-of-specific-ip-phone/ta-p/3137526
new firmware will not affect old IP phones. Unles you manually upload new firmware name under "phone load name" of those device. In this case these phones will upgrade to the new firmware.
Please rate if useful
try following things one by one
1- Delete/Erase IP4 network setting
2- Delete/Erase CTL Trust files
if nothing works above then Reset Telephone Device to factory setting
why you need to install new device pack if the phone is already appearing in phone list?
samhopealpha
Level 2
Level 2
According to
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/firmware/10-3-1-sr3/cs38_b_rn-8831-8831nr-1031sr3.html
Firmware Downgrade Limitation
After you install Firmware Release 10.3(1)SR3 on a conference phone, you cannot downgrade the firmware to a previous version.
as of now, the issues still persist
I have 5 unit of the same batch that having the same problem,
wondering if it a firmware issues
I believe that is the reason
