02-08-2016 01:47 AM - edited 03-17-2019 05:47 AM
Hi ,
I am facing problem with dsp cards . I wnated to know how I can which dsp card handle the calls of the voice port .
I want to use this information to know which PRI is affected by the DSP problem .
I am using cisco 4451 ios 15.4.
Any idea?
02-08-2016 02:04 AM
You can run the command show voice dsp group all to check the dsp status. It should show UP.
regds,
aman
02-08-2016 02:53 AM
I am familiar with this command but it doesn't help to find out to which pri port the dsp related .
02-08-2016 04:49 AM
you can run the below commands in sequence:
first login in the GW
a. term mon
b. debug isdn q931
c. Now place the call.
d. After u place the call, u will find call has gone through port at bottom like se0/0/3:15 with called and calling number
003980: Feb 8 17:43:15.814: ISDN Se0/0/3:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x000C
e. Now run the command show voice dsp detailed which will give output as below with DSP NUM
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 g729r8 36.1.2 busy idle 0 0 0/0/3:15 31 0 7163/7331
f. Now, u can run the command show voice dsp group all also
dsp 1:
State: UP, firmware: 36.1.2
Max signal/voice channel: 43/43
Max credits: 645, Voice credits: 645, Video credits: 0
num_of_sig_chnls_allocated: 30
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 624, reserved credits: 0
Signaling channels allocated: 30
Voice channels allocated: 1
Credits used (rounded-up): 21
Voice channels:
Ch01: voice port: 0/0/3:15.31,
regds,
aman
02-08-2016 04:58 AM
Right now I can't proccess calls on this DSP so I'm looking for somthing like :
DSP from slot 1 process calls from voice port 0/0/0 , 0/0/1 .
DSP from slot 2 process calls from voice port 0/1/0 , 0/1/1.
Is it possible ?
02-08-2016 05:40 AM
No idea, if we can achieve this.
Can u share show version/show diag and show voice dsp detailed from router?
regds,
aman
02-08-2016 03:29 AM
On the 44xx series routers/gateways, the DSPs for the interfaces are on the interface card. DSPs on the motherboard are purely for conferences/transcoding.
GTG
