Relation between PRI port and the DSP card
iptsupport
Level 4
Level 4
Hi ,
I am facing problem with dsp cards . I wnated to know how I can which dsp card handle the calls of the voice port .
I  want to use this information to know which PRI is affected by the DSP problem .
I am using cisco 4451 ios  15.4.
Any idea?
6 Replies 6
Aman Soi
You can run the command show voice dsp group all to check the dsp status. It should show UP.
regds,
aman
I am familiar with this command but it doesn't help to find out  to which pri port the dsp related .
you can run the below commands in sequence:
first login in the GW
a. term mon
b. debug isdn q931
c. Now place the call.
d. After u place the call, u will find call has gone through port at bottom like se0/0/3:15 with called and calling number
003980: Feb  8 17:43:15.814: ISDN Se0/0/3:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x000C
e. Now run the command show voice dsp detailed which will give output as below with DSP NUM
DSP    DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 g729r8        36.1.2 busy  idle      0  0 0/0/3:15  31    0    7163/7331
f. Now, u can run the command show voice dsp group all also
dsp 1:
  State: UP, firmware: 36.1.2
  Max signal/voice channel: 43/43
  Max credits: 645, Voice credits: 645, Video credits: 0
  num_of_sig_chnls_allocated: 30
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 624, reserved credits: 0
    Signaling channels allocated: 30
    Voice channels allocated: 1
    Credits used (rounded-up): 21
    Voice channels:
      Ch01: voice port: 0/0/3:15.31,
regds,
aman
Right now I can't proccess calls on this DSP  so I'm looking for somthing like :
DSP  from slot 1 process calls from voice port 0/0/0 , 0/0/1  .
DSP  from slot 2 process calls from voice port 0/1/0 , 0/1/1.
Is it possible ?
No idea, if we can achieve this.
Can u share show version/show diag and show voice dsp detailed from router?
regds,
aman
Gordon Ross
Level 9
Level 9
On the 44xx series routers/gateways, the DSPs for the interfaces are on the interface card. DSPs on the motherboard are purely for conferences/transcoding.
GTG
Please rate all helpful posts.
