Ring external number simultaneously
MBrooksAirIT
Running CUCM 6.1.4
Hopefully simple question. We have a customer who wants a DN to ring to an external number simultaneously when dialed. Any suggestions on how this can be accomplished?
Many thanx
Jorge Armijo
Level 4
Level 4
You can try with Remote Destinatom Profiles:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsmobmgr.html
This is the link for CUCM 8.5, we have to confirm if it's the same procedure for 6.x ...
For CUCM 6, seems that you can use Mobile Connect:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsmobmgr.html#wpxref99670
Jorge Armijo
Sent from Cisco Technical Support Android App
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
MBrooksAirIT
Found this article: http://www.tek-tips.com/viewthread.cfm?qid=1575474, so Jorge looks like you may be correct.
If Mobile Connect is the answer, anybody know the operational impact of enabling? Any (real) resource impact?
Hi Michael brooks
Look into that good link that Jorge Armijo sent already (rating +5).
In the section Interactions and Restrictions and System Requirements, there you can find the " impact".
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
