Route outgoing PSTN call to the remote gateway
O.Zang
Hi All,
Please Helps solve this case.
I am deploying a multiple site collaboration solution.
I have created route group for all sites.
for Biling purposes I have to route all outgoing PSTN call to the remote gateway on the HQ.
Ip phones using the HQ gateway and it's Device pool are able to call out to the pstn.
But ip phones on other site can't call PSTN numbers.
I have configured a dialpeer to route PSTN from others site to The HQ gateway but still can't place a call.
Below are the Dialpeer that  created:
dial-peer voice 30 voip
description "outgoing call from HQ Premary gateway "
preference 1
destination-pattern .T
session target ipv4:10.163.0.40
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1 pots
trunkgroup Hunt_Outgoing
description "outgoing call in srst mode "
preference 3
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
forward-digits all
dial-peer voice 31 voip
description "outgoing call from HQ secondary gateway "
preference 2
session target ipv4:10.163.0.41
voice-class codec 1
no vad
Thanks in advance for your help.
Hi Nipun Singh Raghav,
I want let you know that I have solved the issue.
The customer's requirement is to route call outgoing to pstn throught the gateway on the main site.
So i just use the local route group of the main site in the  device pool configuration of the branch site.
thank you for your Help Nipun, Java and Dennis
5 Replies 5
Jaime Valencia
what's the detailed call flow you want?
what do the debug say when you try with your current config?
java
if this helps, please rate
Dennis Mink
on the gateway do a debug voip dial-peer to see what dial peer gets hits. also add debug ccsip messages  and state the calling and called numbers
Please remember to rate useful posts, by clicking on the stars below.
Hi Java and Denis
Thank for replying,
Here is the call Flow that I want:
branch site: Trechville-av8
Device Pool: DP_treichville-av8
Route group: LRG_treichville ( I have configure SLRG)
IP Phone DN: 800712
got h323 Gateway  with FXO port ( FXO to be use only in case of faillure.
Main Site: ( outgoing calls  to PSTN are working fine)
DP: DP_SIEGE
route group: LRG-BACKUP-SIEGE
got a H323 gateway with E1 card.
 calls from Ip phone on branch site ( 800712) to PSTN number 58487437 need to be handled by the gateway on the main site.
preference 1
voice-class codec 1
no vad
preference 3
forward-digits all
preference 2
voice-class codec 1
no vad
Below are the debugs output:
calling Number: 800712, called number 58487437
Debug voip dialpeer:
GW_TREICHVILLE-AV8#debug voip dialpeer
voip dialpeer default debugging is on
GW_TREICHVILLE-AV8#
GW_TREICHVILLE-AV8#
GW_TREICHVILLE-AV8#
GW_TREICHVILLE-AV8#
*Jun 19 12:01:21.147: //-1/50B3052D81A4/DPM/dpAssociateIncomingPeerCore:
Calling Number=800712, Called Number=800712, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=30
*Jun 19 12:01:21.147: //-1/50B3052D81A4/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Jun 19 12:01:34.742: //-1/80695E610300/DPM/dpAssociateIncomingPeerCore:
Calling Number=800712, Called Number=58487437, Voice-Interface=0x0,
*Jun 19 12:01:34.742: //-1/80695E610300/DPM/dpMatchSafModulePlugin:
Debug ccsip messages
*Jun 19 11:57:20.313: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.163.7.161 SIP/2.0
Via: SIP/2.0/UDP 10.163.7.164:5060;branch=z9hG4bK2a824c12
From: <sip:800712@10.163.7.161>;tag=0076861bfd520037375f67a9-3e670c82
To: <sip:800712@10.163.7.161>
Call-ID: 0076861b-fd52000c-47a94125-11ac892f@10.163.7.164
Max-Forwards: 70
Session-ID: b06c60db00105000a0000076861bfd52;remote=00000000000000000000000000000000
Date: Tue, 19 Jun 2018 11:56:24 GMT
CSeq: 107 REGISTER
User-Agent: Cisco-CP7821/11.7.1
Contact: <sip:a1600c03-9ea1-908d-64b1-eda78300102e@10.163.7.164:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-0076861bfd52>";+u.sip!devicename.ccm.cisco.com="SEP0076861BFD52";+u.sip!model.ccm.cisco.com="621"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 0
*Jun 19 11:57:20.315: //3326/C126F8CF81A0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:800712@10.163.7.161>;tag=1F3F53E0-1383
Date: Tue, 19 Jun 2018 11:57:20 GMT
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
CSeq: 107 REGISTER
Content-Length: 0
R0g22
You don't need SIP debugs if the gateway is H.323. Enable the following and collect the logs -
debug h225 asn1
debug h245 asn1
debug voice ccapi inout
debug isdn q931
debug voip translation
debug voip dialpeer
