01-21-2014 07:42 AM - edited 03-16-2019 09:22 PM
I have a client that I'm trying to install RTMT on Windows Server 2008 R2 64 bit. When the RTMT .exe is run, there is a pop-up stating that it is not compatible with this version of windows. CUCM 9.x
Is there a compatible version available for Windows server?
Anybody know of a workaround to get RTMT to work with Windows server environment?
Ryan
Solved! Go to Solution.
01-21-2014 08:04 AM
tried various compatibility modes and still won't install.
01-21-2014 07:57 AM
Right click .exe and change compatibility mode to win 2003 and try again
01-21-2014 08:04 AM
10-09-2014 07:38 AM
We are looking at deploying windows 10 when it is released, and I have the same and more questions around Cisco's comparability matrix/road map. First on my list is the Cisco agent desktop App Compatibility, then Jabber, then RTMT (ccm/unity/uccx)… has anyone seen any posting by Cisco on a windows compatibility matrix?
01-21-2014 07:58 AM
Hello Ryan,
as far as i know Windows 2008 is not supported with current road map.
Br,
Nadeem
Please rate all useful post.
04-07-2014 01:18 PM
Ryanhladek - Did you ever get this working? I had the same error trying to install on Server 2012 standard.
[EDIT] - for anyone following this post, I did get it to work on Windows Server 2012 R2 Standard. Application file version 11.5.0.0.
Create shortcut to installer exe, change compatibility to "windows 7" and run as administrator.
05-09-2014 12:52 PM
I have version 11.5.0.0 of CcmServRtmtPlugin.exe and I can't get it installed on server 2012 standard. When I run the installer I get the following:
Installer User Interface Mode Not Supported
The installer cannot run in this mode. To specify the interface mode, use the -I command-line option, followed by the UI mode identifier. the valid UI odes identifiers are GUI, Console, and Silent.
Can you briefly describe what you did to successfully install RTMT on this platform? I have tired changing the compatibility modes as well.
07-19-2021 02:43 AM
Hi All,
Even though this post is very old, just in case someone needed.
In order to run RTMT 11.5 on a Windows Server 2008 R2 I've had to install jre-8u171-windows-x64.exe.
Hope it helps
;D
