06-21-2018 02:49 PM - edited 03-17-2019 01:04 PM
hello, I sometimes look at RTMT to troubleshoot numbers people dialed. I have very basic knowledge in this. When going into Real Time Data field under session trace log view, I see there is a "Calling DN", "Orig Called DN" and "Final Called DN". Can someone explain the difference to me?
Thank you
Solved! Go to Solution.
06-21-2018 03:33 PM
06-21-2018 03:38 PM
here is some description and hope that helps. If you are troubleshooting RTMT is great. If you are just checking the call records, You also can check them at "CDR analysis and reporting section "
https://(name or the IP of UCM)/car/
"Calling DN" - The number that the call is originated
"Orig Called DN" - The original number the caller called before diverting to any other number
"Final Called DN" - the Final destination of the call ex:- could be the original called number if it wasn't forwarded elsewhere otherwise this could be the voicemail or if the Original called number was forwarded this would be the final destination of the call
Cheers
Prabath
06-21-2018 03:33 PM
06-21-2018 03:35 PM
The answer is 42! Is that correct?
haha jk. Thank you for the explanation.
06-21-2018 03:38 PM
Cheers
Prabath
