SCCP or SIP ?
Andrewkai
Dear All,
I have 2811 Router running cme and cue. 4 analogs phones are connected to cme using ATA.
Can individual ATA port be configured to SIP instead of using SCCP?
Any comment would be much appreciated.
Andrew
pn the CME side you would have a dial-peer pointing to the phone running SIP or H.323
Please excuse the nitpick, Aaron.
No dialpeer is necessary. Instead, the phone is configured as SIP phone, a frequently asked questions here on this forum.
11 Replies 11
espereir
Level 5
Level 5
Hi Andrew,
You can load either SIP or SCCP firmware on the ATA, however, both ports are going to register with either Skinny or SIP; I am not quite sure what do you want to acomplish with this, could you please elaborate a little bit?
Thanks and BTW, here is the ATA 186 datasheet: http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps514/ps515/product_data_sheet09186a008007cd72.html
paolo bevilacqua
With SCCP, you can configure the ATA as if they where ephones. SO, the analog phones will enjoy the full CME features, dua
l lines, call waiting, conference, Feature Access Codes, and other.
With SIP, you will have nothing of that, just very basic analog numbers, not really integrated in CME.
I have one non-cisco phone and would like to test with Cisco CME.
But cannot register with CME when I connected that phone to CME using ATA.
Do I need to configure ATA port to support SIP? OR
How can I get that Weatherproof Phone to work with Cisco Voice System?
Andrew
Aaron Harrison
Hi Andrew
That phone that you linked is an IP phone itself.
ATA = Analogue Telephone Adapter. You don't have an analog phone, so you don't need an ATA.
That IP phone supports SIP or H.323, so you'll need to read the manual on how to configure it; on the CME side you would have a dial-peer pointing to the phone running SIP or H.323 depending on how you choose to configure it.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I used the following tutorial but unluckily cannot register non-cisco phone with cme.
I got this error"channel not found" when I use non-cisco ip phone and got another error"registration error:408 request time out" when I use xlite.
http://www.netcraftsmen.net/component/content/article/70-unified-communications/774-sip-endpoints-in-cisco-communications-manager-call-manager-express-x-lite.html
Your kind help would be much appreciated!
Cheer!
Andrew
Hi Guys,
I can manage to register xlite with my CME but cannot register with another sip non-cisco phone.
I can see the name and phone number form the LCD display but there's an error called "UNKNOWN NUMBER". Any idea?
Thanks for your kind support!
Andrew
CME#sh voice register pool 1
Pool Tag 1
Config:
  Mac address is 0050.C26A.50B4
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  DTMF Relay is enabled, sip-notify
  Call Waiting is enabled
  DnD is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  username xlite password xlitetest
  Transport type is udp
  service-control mechanism is not supported
  registration Call ID is NGVjODIzMTJjMzQwYmUxODZmOTEzMjBhOTgxNDllNGE.
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 600
  contact IP address: 192.168.42.35 port 52598
Dialpeers created:
dial-peer voice 40001 voip
destination-pattern 600
session target ipv4:192.168.42.35:52598
session protocol sipv2
dtmf-relay sip-notify
codec  g711ulaw bytes 160
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 1
  Total SIP phones registered: 2
  Total Registration Statistics
    Registration requests  : 3
    Registration success   : 3
    Registration failed    : 0
    unRegister requests    : 1
    unRegister success     : 1
    unRegister failed      : 0
Someone on here may be able to help you get this working, but just an FYI that non-Cisco SIP phones are not supported to CME via registration.  IF the phone can act as a proxy instead of a UA, you can configure it as a SIP trunk to CME, though.
So if you run into any issues on these phones, you won't get support from TAC or development.  Just a heads up.
Thanks Steven! I also hope someone can help me.
I think this non-cisco phone can act as a proxy instead of UA because this phone was tested in other country and it worked with CME.
Sincerely,
Andrew
Hi Guys,
The end of the day I could manage to register non-cisco phone with CME usig SIP.
All you need to do is that you have to understand the boot process of ip phone and concept of how ip phone talks to CME.
And again the following document is very useful for me..
Thank you guys for involving in this discussion.
Also thanks to Netcraftsmen.net. Great job Bill.
Cheer!
Andrew
Aaron Harrison
Ah yes, good point Paulo(+5). I tend to work with CUCM far more than CME, and have rarely had to use SIP phones with CME.
But the main point is if it's SIP/H.323, then an ATA won't be much use.
