07-13-2016 07:25 AM - edited 03-17-2019 07:32 AM
Hi all,
Iam trying to set up self provisioning in my cluster. But I can not get registering my CTI Route Point. do you what is going on?. I did:
Device | ||||||||||||||||
CTI Route Point | ||||||||||||||||
Device Name: CTI_SelfProv | ||||||||||||||||
Description : CTI for Self Provisioning | ||||||||||||||||
Device Pool:none | ||||||||||||||||
Calling Search Space: z_autoregistered | ||||||||||||||||
Line | ||||||||||||||||
Directory Number : 1015 (colud be anyting free extension) | ||||||||||||||||
Route Partition: z_autoregistered | ||||||||||||||||
Description, Alerting Name, ASCII Alerting Name : Self Provision Phones | ||||||||||||||||
Application user | ||||||||||||||||
User ID : User_SelfProv | ||||||||||||||||
Password : 11111 | ||||||||||||||||
Controlled Devices : CTI_SelfProv | ||||||||||||||||
Groups : Standard CTI enable |
But my CTI RP show next status:
Registration: Unknown | |
IPv4 Address: None | |
Solved! Go to Solution.
07-20-2016 06:59 AM
Hi there,
Just for information!
im having the exact same error right now in my system, same software version.
Im in contact with TAC right now, did any of you guys get this solved yet!
The problem is that the route point won't register.
I really don't think that, what you see with the service not activated on the subscriber, is an error, i't supposed to be like that, but, the route point should register anyway.
Regards Rolf
07-20-2016 06:00 PM
Hi Rolf,
Keep posted after the solution is suggested by TAC.
hi Oscar,
is the issue resolved?
regds,
aman
07-22-2016 03:33 AM
So it's seems that we solved out the problem, in my system, on the publisher, the CTI service was not running. The provisioning service was running, but it is depending on the CTI service.
CTI service was activated, Provisioning service was restarted, and then the CTI route point was restarted, and then it registered as it should.
And now the service is working again.
/Rolf
07-14-2016 08:16 AM
Yes, I think this bug is documented wrongly.
I have checked it in 11.0 also, this parameter is not there as well.
You should open a TAC case for further troubleshooting.
Suresh
07-14-2016 07:48 AM
on "publisher" server is running.
Self Provisioning IVR[STARTED]
on "CTI manager" server it exist!!! but is not activated:
Self Provisioning IVR[STOPPED] Service Not Activated
FYI. by "Serviceability" web page dosent exit Self Provisioning IVR service, so I can not acivate!!!
04-16-2018 08:51 AM
I had the same issue. Resolved by restarting CTI and Self Provisioning IVR services on Publisher server. CTI RP registered again.
07-13-2016 08:20 AM
I have the whole procedure on videos
https://www.youtube.com/playlist?list=PLFuOESqSTxEvZChqWgAJanctohRMe99CR
07-06-2021 09:54 PM
i just restarted the IVR auto provisioning service in the pub and it worked
