route pattern
bluesea2010
Level 5
Level 5
I have route plan 9.[25478]XXXXXX  for outbound PSTN calls with predot enables
created a sip trunk to call route between non-cisco PBX and cucm .
i can call between extension PBX(3XXX) nd CUCM(7XXX)
Now I want to initiate   a call 9.2XXXXXX from 3XXXX.
What Pattern should I sent to CUCM
Ratheesh Kumar
hi there
You have to create a new pattern (without any digit strips) in non-Cisco PBX , the points to CUCM SIP Trunk. Once the call reaches CUCM, it will stip 9 and use the 9.[25478]XXXXXX Route pattern
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
It depends on you. From PBX You can send with 9 or without 9.
If you send the call   with 9,your call will match with your CUCM RP 9.[25478]XXXXXX . CUCM will strip the 9 and send it to Your ISP.
From PBX if you dont want  to send 9, on CUCM  create a new RP [25478]XXXXXX and  keep this RP in a new partition. And  assign inbound CSS on TRUNK which can access this new RP.
Response Signature
