SILENCE RING FOR 2 LINES OUT OF 5 LINES ON THE SAME PHONE
Joe1164332
Hello community!
I have a CP-8851 phone with 5 lines. I am responsible for 2 of the 5 lines. I would like to silence the ring of incoming calls for the 3 lines for which I am not responsible (to help me focus). I do not want to change the ringtone or volume or take them off my phone. I want them silenced. Can anyone help or point me in the right direction please?
Thank you! I appreciate your help.
Joe
6 Replies 6
Kevin Martin
Hi Joe,
You can change the ring setting on those lines to Flash Only or to Disabled.  The option in under the line configuration.
Kevin
***Please Mark and Rate helpful posts***
Hi Kevin
Thank you so much! Where can I find the line configuration? It is not on my phone if I click the settings (gear) icon. Thank you!
This is a Call Manager Configuration.  You'll have to login to CUCM and edit the line configuration on the device.
Thank you Kevin ! Very much appreciated.
So is there really no way for the user to do this from their phone?
Users can use the Self Care Portal to specify ringing on individual lines. You could also deploy a new ringtone of "Silence" and allow users to choose that for select lines.
Maren
