SIP 181 support on IOS
bgottlieb
Does Cisco IOS supports SIP 181 messages?
When we make outbound calls to some PSTN numbers and they are call forwarded some times we get SIP 181 messages back that our Cisco 2400 series with 12.4(4)T8 doesn't respond and the calls get killed by the carrier.
7 Replies 7
bretjaquish
Level 3
Level 3
According to this cisco doc they do not:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/647897.pdf
Cisco IOS gateway does not support SIP 181 message (call being forwarded) which causes SDP establishment failure during a call forward
between PSTN phone and Avaya stations. PSTN user does not get ringback. This applies to Call Forwarding (all and busy) calls.
bretjaquish
Level 3
Level 3
This guide will give you a more detailed explanation of which messages are accepted:
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/12_4t/sip_12_4t_book.pdf
The Cisco Voice Configuration library is a good summary link for voice configuration/troubleshooting:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_voice_configuration_library_glossary/vcl.htm
Here is the excerpt from the SIP configuration guide about SIP responses (including 181).
SIP Responses
Table 5 through Table 10 show SIP responses that are supported by Cisco SIP gateways in compliance
with RFC 3261.
Cisco SIP gateways do not initiate the use of keepalive messages for calls that they originate or terminate. If the remote gateway uses a keepalive message, the SIP gateway complies.
INVITE Yes. SIP gateways support midcall Invite requests with the same call-ID
but different Session Description Protocols (SDP) session parameters(to change the transport address).
Midcall INVITE requests can also change the port number, codec, or refresh the session timer value.
INFO Yes. SIP gateways can accept and generate INFO messages.
NOTIFY Yes. Used in implementation of the Refer requests. Notify messages let the initiator of the Refer request know the outcome of the transfer.
Notify messages also let a subscriber know of any changes occurring in selected events, such as dual tone multifrequency events (DTMF) or
message waiting indication (MWI) events.
OPTIONS Yes. SIP gateways receive this method only.
PRACK Yes. Enable or Disable Provisional Reliable Acknowledgements
(PRACK).
REFER Yes. The SIP gateway responds to a Refer request and also generates a Refer request for attended and blind call transfers.
REGISTER Yes. The SIP gateway can send and receive SIP REGISTER requests.
SUBSCRIBE Yes. The SIP gateway can generate and accept SUBSCRIBE requests.
The gateway processes SUBSCRIBE requests for selected applications such as DTMF telephony events and for MWI.
UPDATE Yes. The SIP gateway can accept UPDATEs for media changes, target
refreshes, and QoS scenarios. The gateway will send UPDATEs only for QoS scenarios.
Table 4 SIP Methods (continued)
Method Supported by Cisco Gateways?
Table 5 1xx Responses
1xx Responses Comments
100 Trying Action is being taken on behalf of the caller, but that the called party has
not yet been located. The SIP gateway generates this response for an
incoming Invite request. Upon receiving this response, a gateway stops
retransmitting Invite requests and waits for a 180 Ringing or 200 OK
response.
180 Ringing The called party has been located and is being notified of the call. The
SIP gateway generates a 180 Ringing response when the called party has been located and is being alerted. Upon receiving this response, the gateway generates local ringback, then it waits for a 200 OK response.
Achieving SIP RFC Compliance
Information About SIP RFC Compliance 8
181 Call is being forwarded The call is being rerouted to another destination.
The SIP gateway does not generate these responses.
Upon receiving these responses, the gateway processes the responses in
the same way it processes a 100 Trying response.
182 Queued The called party is not currently available, but has elected to queue the
call rather than reject it.
183 Session progress Performs inband alerting for the caller.
The SIP gateway generates a 183 Session progress response when it
receives an ISDN Progress message with an appropriate media indication
from the PSTN.
181 Messages may not need a response since they are 1xx series messages. You would need to check whether or not reliable 1xx messaging (rel1xx) is in the supported/required field of the response or request from the other endpoint. As well, you would probably want to try newer code like 12.4(20)T for better SIP support.
hth,
nick
csmith5660
So is there a way to fix this? Who's not following the SIP standard, the carrier or Cisco?
Post the complete trace and relevant config.
csmith5660
Paolo,
The router is IOS 15.0(1r)M1 - at this point all I know from my client is that their provider Paetech/Windstream shows that our end does not respond to the 181 message when transfering or forwarding a call from a cell phone to it's VM do to a RNA.  We are fairly certain that it's only specific cell phone carriers that insist on a response.  AT&T and T-mobile seem to have the issue while Spring and Verizon do not.
At this point I'm just trying to figure out if there is a way to force the gateway to respond to the 181 so that the calls will stop failing.
If there are specific traces you migh find helpful in the situation let me know.
Craig
You posted rommon version,not IOS version.
The trace to take is "debug ccsip message" one for a working, and one for a non-working call.
