SIP 183
zeinab.mahdavi
HI,
what is SIP 183 response ? can I confige it on the cisco gateways ? I think it is used for call queueing
anchoudh
Level 9
Level 9
Hi Zeinab,
Please refer the below links,
http://www.cisco.com/en/US/partner/docs/ios/voice/sip/configuration/guide/sip_cg-msg_tmr_rspns.html
http://www.cisco.com/en/US/partner/docs/ios/12_2t/12_2t13/feature/guide/ft180sdp.html
Hope it helps.
Anand
Pls rate helpful posts by clicking on the stars below the right answers !!
Anchoudh, can you post publicly accessible links please ?
GTG
Please rate all helpful posts.
abarkalg
Hi Zeinab,
                  In simple language we can explain SIP 183  message as a Provisional Ack message for a call which is still being set  up.
If we recieve a Session progress 183, then the media will start flowing from the farend to our side and vice verca.
If you make a call from your side to the PSTN, then , There will be an
Originating               Terminating
Gateway                    Gateway
           INVITE
          100 Trying
     183 Session Progress (One way SDP)
       One way voice path
               200 OK
               ACK
           Two Way Voice Path
then we get Bye, Release, Release complete, and then 200 OK  .
hope this helps.
Abdul Sattar
Please rate helpful posts!!!
