CISCO PHONE TIME CORRECTION
cmabindla
Good day SIr/Madam
The CISCO Phone time is not correct how can I change their time to be correct.
5 Replies 5
Dennis Mink
What product?
Please remember to rate useful posts, by clicking on the stars below.
George Sotiropoulos
Can you clarify which Cisco IP Phone model (88XX? 79XX)and on what platform it is registered (CUCM or CME)?
Kind regards,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Good day George
We are using CISCO Unified CM Console (System version: 9.1.2.12901-3 Unrestricted
Have the following CISCP Phone Models:
CISCO IP PHONES CP -6941
CISCO IP PHONES CP-6911
CISCO IP PHONES CP-7821
There's a Voice Server
CHUMA MABINDLA
1) The phone will get time from CUCM & CUCM will Get Timing from NTP.
So to fix the issue you have to make sure CUCM is getting the correct time from NTP.
2) Do an SSH Session to CUCM and execute below command to check
utils ntp status
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
You will need to connect via SSH to your CUCM Pub and issue the command "utils ntp status" to identify if everything is fine.
You may find all the info you need on the following post:
https://community.cisco.com/t5/collaboration-voice-and-video/changing-the-ntp-source-in-cucm-from-cli-and-other-helpful/ta-p/3157615
Hope This Helps
George
