SIP Config Help
jwood1650
I am unable to receive calls to my IP phones when I dial my DIDs.  I can make calls out just fine, just not sure why I can't call in.  To test I use my cell phone to place a call to my DID (provided my flowroute) and I just get a disconnect tone a few seconds later.
Attached is my current config (FYI I'm new to VOIP and this is a home setup, so any modes that need to be made won't effect anything important)
Cisco 2821 / C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M8
CME 8.0
Cisco 7975
Flowroute SIP provider
Thank in advance for the help
38 Replies 38
Can you help me with background too:
CME#dir
Directory of flash:/Desktops/320x216x16/
  155  -rw-         184   Jul 2 2014 12:18:30 -05:00  List.xml
   49  -rw-      571118   Jul 2 2014 05:51:50 -05:00  7975G-Wallpaper.png
   50  -rw-       53964   Jul 2 2014 05:56:04 -05:00  7975G-Wallpaper-Thumb.png
________________________________________________________________
tftp-server flash:/Desktops/320x216x16/7975G-Wallpaper.png
tftp-server flash:/Desktops/320x216x16/7975G-Wallpaper-Thumb.png
tftp-server flash:/Desktops/320x216x16/LIST.xml alias Desktops/320x216x16/List.xml
Jul  2 17:20:27.988: TFTP: Looking for Desktops/320x216x16/List.xml
Jul  2 17:20:31.980: TFTP: Looking for Desktops/320x216x16/List.xml
Jul  2 17:20:35.980: TFTP: Looking for Desktops/320x216x16/List.xml
Jul  2 17:20:39.980: TFTP: Looking for Desktops/320x216x16/List.xml
From what I understand, I have everything configured correctly, but my 7975G  isn't loading the xml file...  Any ideas.
It looks like there is a difference in the List.xml
In the below you have entered list in CAPITAL:
Kindly change it to list.xml and try again
DJ
**Please rate useful posts.
Debugs as requested
It messed up the dial-peers configuration, please take a deep breath and have a little walk smiley and then remove other dial peer (10,11 & 12) make sure dial-peer looks like below and then dial 9137129524, currently call is hitting to dial-peer 0 (because there is no dial-peer ocnfigured to receive 19137129524) and again it trying to go out using dial-peer 1..
dial-peer voice 1 voip
 translation-profile outgoing addlocal
 destination-pattern 1[2-9]..[2-9]......T
 no modem passthrough
 session protocol sipv2
 session target dns:sip.flowroute.com
 incoming called-number .
 translation-profile incoming GRP_1001_1002
 dtmf-relay rtp-nte
 no vad
Suresh
Awesome that did the trick for 9137129524, but still nothing for 7852465184
Attached is current config
Good to know that, add below translation rules under "voice translation-rule 12" and then check..
rule 4 /^17852465184/ /2000/
 rule 5 /17852465184/ /2000/
Suresh
You rock!!! That rang through too.  Couple of tweeks...
7852465184 I would like only to ring 1002
And is there a way to have the caller ID drop the +1 and only show the 9 digit phone number?
Do I need to clean anything up out of my config, is there any that is in there that needs to be removed?
Try this for ringing only on 1002.
 rule 1 /^19137129524/ /2000/
 rule 2 /19137129524/ /2000/
 rule 3 /9137129524/ /2000/
no rule 4 /^17852465184/ /2000/
 no rule 5 /17852465184/ /2000/
 rule 4 /^17852465184/ /1002/
 rule 5 /17852465184/ /1002/
 rule 6 /7852465184/ /1002/
That did it...
 When I dial out, will 1002 show that 785 # and 1001 show 913?
Later on when I add more phones, do I simply just modify the voice-translation rule to point to the extension I want? For example:
voice hunt-group 1 parallel
 list 1001,1002,1003  <---- 1003 being future line
 pilot 2000
Yes that is correct.
Instead if you want all the calls to ring a particular number for instance 2000 which is the pilot for the hunt-group.
you can just use a single translation-pattern
rule 1 /^.*/ /2000/
Which means any number will be matched and will be converted to 2000, which will be the pilot of voice hunt group.
ephone-dn  1
 number 1001
 label Home
 name Home
ephone-dn  2
 number 1002
 label Office
 name Office
ephone  1
 device-security-mode none
 description Home Line
 mac-address C062.6B62.143A
 button  1:1
ephone  2
 description Office
 mac-address E8BA.70FB.36E2
 button  1:1
bold replace by 2
I noticed that, made the correction. Thanks
You can put below command as "GRP_1002 & PROVIDER_in" profiles are not associated anywhere.
no voice translation-rule 10
no voice translation-profile GRP_1002
no voice translation-profile PROVIDER_in
As per logs, calling number and called number are +17024011492 & 19137129524  respectively for internal call to CME.What caller ID you are getting on Cisco phone and what you want ? I am asking this because you said 9 digits but there are 10 digits number if we exclude 1.
Suresh
Suresh
When I call from my cell I see the +1702401XXXX, I want the +1 dropped and only show the 702401XXX
as I told you need
for incoming calling number
1. incoming translation rule
2. incoming traslation profile
