10-13-2020 05:02 AM
Hi Folks, Integrating a CUBE with CUCM V12.0 and I have outgoing calls OK but incoming calls fail. When I do a "debug ccsip messages" I can see that I am receiving a 401 error message from CUCM back to the CUBE thus. Any ideas as its driving me crazy. I thought the authorization was between the CUBE and ITSP not back to the CUCM. CUCM doesn't even ask for any authentication credentials.
1163167: Oct 13 12:43:56.582: //4646986/35F5A25BAD70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.18.96.100:5060;branch=z9hG4bKD0C1FF4
From: <sip:+12345678910@172.18.96.100>;tag=455B1FC5-1099
To: <sip:+09876543211@172.18.96.61>;tag=1424739835
Date: Tue, 13 Oct 2020 10:02:06 GMT
Call-ID: 35F8AFBC-C8011EB-AD76F7E1-5FB58DC1@172.18.96.100
CSeq: 101 INVITE
Allow-Events: presence
Server: Cisco-CUCM12.0
WWW-Authenticate: Digest realm="StandAloneCluster", nonce="EadwbDYHTSzxpX4iMUj/otBZVpT7jYqm", algorithm=MD5
Content-Length: 0
10-13-2020 07:30 AM
10-13-2020 08:35 AM
10-13-2020 08:46 AM
Check the SIP Trunk configuration and the SIP Trunk Security Profile in CUCM. It looks like it's expecting authentication.
10-13-2020 09:34 AM
10-13-2020 09:12 AM
Yeah thats what I thought as well but there is nothing selected in the sip trunk security profile.
10-13-2020 09:43 AM
As that is a required setting on a SIP trunk I would say that you're likely not looking at the right place.
The highlighted part is what you need to check.
