SIP phone in SRST
Anil Sharma
Level 3
Level 3
I have worked on configuration of SCCP phones in SRST.
Can anyone help me what are the different configs that are needed to make SIP phones work in SRST ?
Many Thanks
Anil Sharma
You need to configure SIP SRST, that's a completely separate configuration in IOS than SCCP SRST.
See more at this link, http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_call_handling.html#wp1052492
Please remember to rate all useful posts.
Response Signature
5 Replies 5
Robert Thomas
Level 7
Level 7
CME as SRST? Or regular SRST?
Can you post your SCCP configuration?
Thanks for your reply Robert. Its a regular SRST
call-manager-fallback
secondary-dialtone 0
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 4
timeouts ringing 90
ip source-address 10.216.32.4 port 2000
max-ephones 300
max-dn 500 dual-line
system message primary IN SRST
transfer-pattern .T
no huntstop
translation-profile incoming 4-DIGIT-SRST
call-forward pattern .T
moh music.wav
multicast moh 239.1.1.1 port 16384 route 10.216.32.4
time-zone 45
time-format 24
date-format dd-mm-yy
Response Signature
Hello Roger,
Many Thanks .. One question
What does the command max-pool defines ?? I didnt clearly understood it
voice register global
max-dn 500
max-pool 165
Anil Sharma
max-pool is equivalent to max-ephone. Aka maximum number of phones that can register to either of the SRST sub instances.
Response Signature
