SIP Phones don't re-register on CUCM after SRST finished
cbonnal35
I have a 2901 router as MGCP gateway on the CUCM.
When link between router and CUCM fails, SCCP and 3rd party SIP phones register correctly on the 2901.
But when SRST finishes and network returns in normal conditions, SIP phones keep registered on 2901 whereas SCCP phones re-register on CUCM.
I think 2901 doesn't aware that SIP Proxy CUCM is online, it may be a keepalive command to add or something but I've not found.
Here is a part of my conf :
Subscriber IP : 192.168.11.2
Publisher IP : 192.168.11.1
2901 IP : 172.16.39.253
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g726r32
voice register global
system message /!\ Mode de secours actif /!\
max-dn 4
max-pool 4
voice register pool  1
id network 172.16.36.0 mask 255.255.255.0
preference 2
proxy 192.168.11.2 preference 1 monitor probe icmp-ping
voice-class codec 1
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.11.1
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.11.2 192.168.11.1
ccm-manager config
mgcp
mgcp call-agent 192.168.11.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.11.1 identifier 10 version 7.0
sccp ccm 192.168.11.2 identifier 20 version 7.0
sccp
sccp ccm group 1
associate ccm 20 priority 1
associate ccm 10 priority 2
switchback method graceful
call-manager-fallback
max-conferences 2 gain -6
transfer-system full-consult
user-locale FR
ip source-address 172.16.39.253 port 2000
max-ephones 30
max-dn 30
system message primary /!\ Mode de secours actif /!\
system message secondary Mode degrade actif
no huntstop
alias 1 7440 to 8888 preference 3
time-format 24
date-format dd-mm-yy
Thank for your help !
Clement
Hi Clement,
When phones fallback to SRST mode is because have been 3 missed TCP Keepalive between phones and CUCM. When wan connection is retored; phone re-established TCP connection with CUCM so that's when they re-register with CUCM. So the router never send a message telling the phone they need to go back to re-gister with CUCM.
What phone model you're working with?
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
It's Polycom DECT 3rd party SIP phones.
These DECT are connected to a Polycom KWS8000 Wireless Server, and this is the KWS8000 which convert streams to IP and establish SIP sessions with CUCM.
All proxies are configured in the KWS8000, so when subscriber is not available, it tests the second proxy, and finish by SRST.
But when subscriber becomes available, it keeps connection to 2901 because link with it is already OK, so no reason to change.
I think it was 2901 job to inform phones that original proxy is now avalaible as it is not in SRST mode anymore ?
The 2901 should not inform the phones to register back to the CUCM.
From the SRST System Administrator Guide:
In SIP phone load 8.0 and later versions, SIP phones use keepalive to maintain a connection with Cisco Unified SRST during active registration with Cisco Unified Communications Manager. Every two minutes, a SIP phone sends a keepalive message to Cisco Unified SRST. Cisco Unified SRST responds to this keepalive with a 404 message. This process repeats until fallback to Cisco Unified SRST occurs. After fallback, SIP phones send a keepalive message every two minutes to Cisco Unified Communications Manager while the phones are registered with Cisco Unified SRST.
Bryan Geoghan
Did you ever find a solution to your issue? I'm running into the same issue with Cisco 7962s that are running SIP.
