06-22-2024 06:41 AM
Hello There...
I have cisco 2900 series router and we transformed to sip trunk recentrly, does this router model supports sip? needs a special license?
and how's the configurations please.
My network design is like this PSTN>>>Voice GW Router 2900>>>FIREWALL>>>Call Manager
06-24-2024 11:56 PM
Thanks so much for your kind help,
This is my first time configuring a router to act as SBC, I will find workaround to how config SBC features.
06-25-2024 04:53 AM
In my first response to your post there is a link to a document for how to configure a Cisco router as an SBC by using the Cube functionality. It’s not a direct reference for how to configure it to fit the needs for your specific service provider, you’d need to get the specifics for that from the SP and then adopt the configuration to fit your needs.
06-25-2024 12:54 AM
Please, does it need any special license to act as SBC?
06-25-2024 04:53 AM
You’ll need SIP trunk licenses.
06-23-2024 03:31 AM - edited 06-23-2024 03:35 AM
I appreciate your time and effort
07-08-2024 01:42 AM
The 2900 has reached its EOL and the replacement which is 4k also announced its EOL which reach on 2028, You need a new hardware which will be 8200 or 8300 based on your requirements. CUBE is a licensed feature, you need to procure the license based on how many sessions you subscribe with the ITSP.
I would suggest to reach out to a local Cisco partner who is good in collaboration in your region who can assist you on proposing a solution and also ask him to include the PS which include the configuration of the CUBE feature.
07-08-2024 06:57 AM
Hello Dear,
Our cisco supplier has recommended to tech refresh for the voice gateway, The cisco 2911 platform doesn't support CUBE feature/licensed as advised by cisco.
The question is, Does cisco C8200 is appropriate platform for this matter?
Thank you and I appreciate your help in answering.
07-08-2024 10:09 AM
Yes there are 8200 model(s) that are suitable for voice services.
07-06-2024 11:40 PM
The Cisco 2900 Series routers do support SIP (Session Initiation Protocol) trunks, which are commonly used for VoIP (Voice over IP) communications. However, there are specific requirements and configurations needed to enable this functionality.
Configure SIP Trunk on Voice Gateway:
Configure Dial Peers:
Configure Call Manager:
Below is a basic example of how you might configure SIP on a Cisco 2900 Series router:
Add SIP Trunk:
Route Patterns:
Security:
Ensure your network best design allows for the proper flow of SIP traffic:
Make sure that the firewall rules allow SIP and RTP (Real-Time Protocol) traffic between the voice gateway and the Call Manager. Additionally, NAT (Network Address Translation) settings should not interfere with SIP signaling.
Ensure you verify these configurations with your specific environment and consult the relevant Cisco documentation for detailed and specific commands and configurations tailored to your needs. For more information, you can visit this link.https://iiganony.com/
