SIP Trunk CUCM to Avaya remote = 503.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-10-2018 03:15 PM - edited 03-18-2019 12:26 PM
Hi guys,
I have a trunk from my CUCM to an Avaya, the SIP trunk was working fine, but suddenly the following error appeared, remote = 503, If I arrive by ICMP to the IP of the Avaya, I have restarted the SIP Trunk and the behavior is the same.
Thanks for the help.
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 04:17 PM
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 04:23 PM
I have marked MPT, and the behavior is the same, I have also tried to remove it and the behavior is the same.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 05:29 PM
CCM Traces will be your best bet. Also try “Early Offer support for voice and video calls (insert MTP if needed )" in your CUCM SIP Trunk’s SIP Profile.
Hope this helps
Cheers
Rath!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 07:50 PM
Hi Stobar,
1) Make sure there is no changes made on Firewall in terms of port 5060 (or any other that is being used by CUCM-Avaya trunk.
2) Please send us the output of "utils dbreplication runtimestate" on Publisher of CUCM.
3) Is "Run On All Active Unified CM Nodes" option checked on the trunk configuration page?
Priyam Acharya
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 07:58 PM
1) Does not pass through any Firewall.
2) I attach the result of the command utils dbreplication runtimestate
admin:utils dbreplication runtimestate
Server Time: Sun Jun 10 20:52:34 CST 2018
Cluster Replication State: BROADCAST SYNC ended at: 2018-03-05-15-57
Sync Result: SYNC COMPLETED on 706 tables out of 706
Sync Status: All Tables are in sync
Use CLI to see detail: 'file view activelog cm/trace/dbl/20180305_155444_dbl_repl_output_Broadcast.log'
DB Version: ccm11_5_1_14900_11
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from CUCM-CAD-PUB (2 Servers):
PING DB/RPC/ REPL. Replication REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & Details
CUCM-CAD-PUB 192.168.61.84 0.016 Y/Y/Y 0 (g_2) (2) Setup Completed
CUCM-CAD-SUB 192.168.61.85 0.488 Y/Y/Y 0 (g_3) (2) Setup Completed
3) If this option is checked.
Thanks for the help,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2018 08:38 PM
Please collect packet captures from CUCM nodes and try resetting the SIP trunk in question.
Make sure before you collect packet captures under Device >> Device Settings >> SIP Profiles >> "Enable OPTIONS Ping to monitor destination status for Trunks with Service Type "None (Default)" is checked.
Priyam Acharya
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2018 05:35 AM
Because this has been working before; are you using TLS across this trunk? If so have you checked for expired certs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2018 03:52 PM - edited 06-11-2018 03:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2018 03:55 PM
Hello everyone,
They have found an inconvenience in Avaya, on that side there was the problem.
The weird thing is that Avaya always appeared UP.
Saludos,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2018 07:27 PM
awesome! what was it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2018 07:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-14-2022 05:06 PM
Problem Clarification
Case 1: SIP trunk between IP office and Call Manager.
When there is an incoming call from CUCM to IP Office, IP Office displays 503 service unavailable, destination incompatible cause 88.
Case 2: Cause code 88 - Incompatible destination.
Solution
Case1: Cisco Call Manager is sending the invite to IP Office without SDP and IP Office is rejecting the call with 503 service unavailable.To be fixed from CUCM side.
OR
Case2: Enable the option "Allow Empty INVITE" in SIP Advanced tab, this will allow the call to be established from IP Office without SDP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-15-2022 12:36 AM
Why you answering to a post, that's already years old and also seems to solved?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-15-2022 10:11 AM
Because as mentioned by stobar1101: "The Avaya provider did not tell us what the problem was, but it took 4 days to restore the service."
I had a recent situation that is similar and I wanted to post the solution applied.
