SIP Trunk in India
Can we use SIP trunk in India ? If yes then what are limitations ?
Please share link of doc as proof so i can share the same with management . If you can share something from TRAI side that will be great.
Suresh Hudda
This has been discussed so many times here on support forums, you may do Google and will find plenty of info in detail.
Short answer of this question-- Yes, you can configure trunks and can use them for incoming and outgoing calls but make sure your organization doesn't violate TRAI rules (most imp rule- don't mix up pstn and sip calls), rules in simple words can be find on below link, but for proof you need to go through TRAI' website.
https://supportforums.cisco.com/blog/12539601/trai-india-regulations-voipip-telephony
Suresh
