Virtual CUCM
alfredobosca
I have virtualized CUCM on ESXi and now I don't see any "version active". However on Production CUCM I see a few version active.
Why have disappeared?
Best Regards,
Aman Soi
the snapshot shows Call Manager version which is installed in the active partition.
for ESXi version, u can login through vsphere client and get the detailed version
regds,
aman
Jaime Valencia
If you mean you see more things listed when you do a sh version active, that's simply because you have installed those in a cluster, but not on the other.
java
if this helps, please rate
Deepak Rawat
8.5.1.10000-26 is the active CM version only. You might be able to see something else as well on production CM when you run that command but that might be some cop files etc that you have installed on the server for some purpose. There is no issue in the output that you have pasted here.
Deepak
