SIP Trunk Problem
scr.sybex1
Dear,
I have cucm 11.5
I have problem with configuring sip on cube, my scenario is like below:
ITSP---------CUBE----------CUCM-----------IP Phone
I have no incoming and outgoing call.
the problem is that when i call the sip number from PSTN or my cellphone. the ip phone ring and answer the phone but i haven't any ring back or voice from the ip phone. and the call disconnect after exactly 20 seconds.
as i see debug ccsip message it disconnect SIP 2.0 504 gateway timeout with cause=102.
I attach debug ccsip message and ccapi inout and cube configuration.
i configure the CUCM side with All default parameter(1.standar sip profile 2.non secure sip trunk security profile 3.MTP required is Checked 4.Correct MRGL 5.g711alaw 6.change min-se to 90 and sip session timer to 300)
i appreciate if someone could help me.
thanks
23 Replies 23
Dennis Mink
your sip trace only contains the sip signalling between 172.16.47.1 and 172.16.50.20.
what are these ip addresses. the .1 is your cube by the looks of it?
there is no 200OK in the 101 invite, suggesting the called phone was not picked up. the cancel comes from 172.16.47.1
incoming dial peer is 310 and outgoing 311, can you add the sip debug from what exactually leaves your cube to and from itsp
Please remember to rate useful posts, by clicking on the stars below.
172.16.47.1 is loopabck on cube
and 172.16.50.20 is cucm-pub ip address
Saurabh
Went through your logs, was able to find the disconnect cause code =102 ie timer getting expired.
That is because you are sending 180 ringing to provider with 100 rel required , and provider does not acknowledges it. Check with provider or disable 100 rel required in cube.
the ip phone ring on cucm side but no ringback send to PSTN Caller. and
even if ip phone answer the call the call disconnect after exactly 20 sec.
The cancel is send after 19 seconds by the CUBE, THis could be probably because of RTP inactivity, the interesting part is that no 200 OK came from the CUCM on these debugs even when you say you have answered the call.
Please collect detailed CCM traces for an event and attach it here, when you collect that also run simultaneous debugs for:
–debug ccsip calls
–debug ccsip error
–debug ccsip messages
-debug ccsip events
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200787-How-to-Collect-Traces-for-CUCM-9-x-10-x.html
kindly include the calling and called number along with the timestamp
Please rate if found helpful
Aeby
Please rate if you find this helpful.
Aeby
007905: Mar 1 12:29:15.525: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.198.21.82:5060 SIP/2.0
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKv7je575gg9x4ei43v6el9vii5;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 6iv5gv5g6jxu5647l5vhgxohvhuxg9gv@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Contact: <10.153.101.165:36616>;expires=65535
Accept: application/sdp
Max-Forwards: 70
Content-Length: 0
007906: Mar 1 12:29:15.525: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
007907: Mar 1 12:29:15.525: //68482/FD448E47913E/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
007908: Mar 1 12:29:15.525: //68482/FD448E47913E/SIP/Error/sipSPIUpdateCallInfo:
input argument error
007909: Mar 1 12:29:15.525: //68482/FD448E47913E/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
007910: Mar 1 12:29:15.525: //68482/FD448E47913E/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
MF:video profile Dial-peer is absent..
007911: Mar 1 12:29:15.525: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
007912: Mar 1 12:29:15.525: //68482/FD448E47913E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=42BE4824-1F38
Date: Thu, 01 Mar 2018 12:29:15 GMT
Server: Cisco-SIPGateway/IOS-15.5.1.T1
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7361 6038 IN IP4 10.198.21.82
s=SIP Call
c=IN IP4 10.198.21.82
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
007913: Mar 1 12:29:16.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007914: Mar 1 12:29:16.017: //68482/FD448E47913E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:16 GMT
CSeq: 1 OPTIONS
Accept: applic
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#ation/sdp
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007915: Mar 1 12:29:17.013: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007916: Mar 1 12:29:17.013: //68482/FD448E47913E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:17 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007917: Mar 1 12:29:19.009: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007918: Mar 1 12:29:19.009: //68482/FD448E47913E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:19 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007919: Mar 1 12:29:21.661: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:42403000@10.198.21.82:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKo74ggb2bx54ax695b8l2bgb65;Role=3;Hpt=8f38_16
Record-Route: <10.153.101.165:5060>
Call-ID: isbc6czezxzaw0hvxj6zz0bjzav0vhhv9b1c@UAC
To: <42403000>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Contact: <77622027>
Max-Forwards: 69
User-Agent: Huawei SoftX3000 V600R013
Session-Expires: 300
Min-SE: 90
Content-Length: 340
v=0
o=- 5910515 5910515 IN IP4 10.153.101.165
s=SBC call
c=IN IP4 10.153.101.165
t=0 0
m=audio 13750 RTP/AVP 8 0 18 3 97 96
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 telephone-event/8000
a=rtpmap:96 RED/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
007920: Mar 1 12:29:21.661: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
007921: Mar 1 12:29:21.661: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
007922: Mar 1 12:29:21.661: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:171775E8
007923: Mar 1 12:29:21.661: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:300, SE Refresher:none, Min-SE Value:90, flags:2001
SIP: (68483) Attribute mid, level 1 instance 1 not found.
SIP: (68483) setup attribute, level 1 instance 1 not found.
SIP: (68483) connection attribute, level 1 instance 1 not found.
SIP: (68483) Attribute label, level 1 instance 1 not found.
SIP: (68483) a=framerate attribute, level 1 instance 1 not found.
007924: Mar 1 12:29:21.661: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
007925: Mar 1 12:29:21.661: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:17173F98
007926: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
007927: Mar 1 12:29:21.665: //68484/00ECD6C1913F/SIP/Error/sipSPIGetCallServerGroupTargets:
No server group configured
007928: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
007929: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
Unexpected VoIPCodec Type :No Codec
007930: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
007931: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
007932: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
007933: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: (68484) Group (a= group line) attribute, level 65535 instance 1 not found.
007934: Mar 1 12:29:21.665: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
007935: Mar 1 12:29:21.669: //68484/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
007936: Mar 1 12:29:21.669: //68484/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:1716FDF0
007937: Mar 1 12:29:21.669: //68484/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:300, SE Refresher:none, Min-SE Value:90, flags:2001
007938: Mar 1 12:29:21.669: //68484/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
007939: Mar 1 12:29:21.669: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <42403000>
Date: Thu, 01 Mar 2018 12:29:21 GMT
CSeq: 1 INVITE
Content-Length: 0
007940: Mar 1 12:29:21.669: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:42403000@172.16.50.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.49.2:5060;branch=z9hG4bK542A11
Remote-Party-ID: <77622027>;party=calling;screen=no;privacy=off
To: <42403000>
Call-ID: EE0F11-1C8311E8-9145D287-199A1C11@172.16.49.2
Min-SE: 90
Cisco-Guid: 0015521473-0478351848-2436878983-0429530129
User-Agent: Cisco-SIPGateway/IOS-15.5.1.T1
CSeq: 101 INVITE
Timestamp: 1519907361
Contact: <77622027>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 8595 4859 IN IP4 172.16.49.2
s=SIP Call
c=IN IP4 172.16.49.2
t=0 0
m=audio 16664 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
007941: Mar 1 12:29:21.673: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <42403000>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
007942: Mar 1 12:29:21.729: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <42403000>;tag=834550~df49f916-efd4-44db-87ad-33d27562197c-18616058
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM11.5
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: f1d3ddbc5db75e8583c80bba18616059;remote=827531a2344775c71d0629d9ab834550
P-Asserted-Identity: "Ali.Vaghefi" <1350>
Remote-Party-ID: "Ali.Vaghefi" <1350>;party=called;screen=yes;privacy=off
Contact: <42403000>
Content-Length: 0
007943: Mar 1 12:29:21.729: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 77622027
007944: Mar 1 12:29:21.729: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 42403000
007945: Mar 1 12:29:21.729: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
ReqLine IP addr does not match with host IP addr
007946: Mar 1 12:29:21.729: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
007947: Mar 1 12:29:21.729: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
007948: Mar 1 12:29:21.729: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
007949: Mar 1 12:29:21.729: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:17176300
007950: Mar 1 12:29:21.729: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007951: Mar 1 12:29:21.729: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
007952: Mar 1 12:29:21.729: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <42403000>;tag=42BE6060-157B
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007953: Mar 1 12:29:22.157: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
007954: Mar 1 12:29:22.157: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007955: Mar 1 12:29:22.157: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Thu, 01 Mar 2018 12:29:22 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007956: Mar 1 12:29:22.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007957: Mar 1 12:29:22.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007958: Mar 1 12:29:23.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
007959: Mar 1 12:29:23.153: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007960: Mar 1 12:29:23.153: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Thu, 01 Mar 2018 12:29:23 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007961: Mar 1 12:29:23.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007962: Mar 1 12:29:23.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007963: Mar 1 12:29:23.521: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bK6ix39uju47exh3hul333u347e;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: ej3j7lv44h9jio77o593j6996heglgg9@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007964: Mar 1 12:29:23.521: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
007965: Mar 1 12:29:23.521: //68485/0208A7509146/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
007966: Mar 1 12:29:23.521: //68485/0208A7509146/SIP/Error/sipSPIUpdateCallInfo:
007967: Mar 1 12:29:23.521: //68485/0208A7509146/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
007968: Mar 1 12:29:23.521: //68485/0208A7509146/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
007969: Mar 1 12:29:23.521: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
007970: Mar 1 12:29:23.521: //68485/0208A7509146/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=42BE6760-149C
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5164 1764 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007971: Mar 1 12:29:24.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007972: Mar 1 12:29:24.017: //68485/0208A7509146/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:24 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007973: Mar 1 12:29:25.013: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007974: Mar 1 12:29:25.013: //68485/0208A7509146/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:25 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007975: Mar 1 12:29:25.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
007976: Mar 1 12:29:25.153: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007977: Mar 1 12:29:25.153: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007978: Mar 1 12:29:25.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007979: Mar 1 12:29:25.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007980: Mar 1 12:29:27.013: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007981: Mar 1 12:29:27.017: //68485/0208A7509146/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:27 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007982: Mar 1 12:29:29.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
007983: Mar 1 12:29:29.153: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007984: Mar 1 12:29:29.153: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Thu, 01 Mar 2018 12:29:29 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007985: Mar 1 12:29:29.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
007986: Mar 1 12:29:29.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
007987: Mar 1 12:29:31.513: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bK9i646ij6ve9o64jh3iolgu5e3;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 796xl5h6hgje93u3x3liv3eli3jh5lhg@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007988: Mar 1 12:29:31.513: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
007989: Mar 1 12:29:31.513: //68486/06CC24CA9147/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
007990: Mar 1 12:29:31.513: //68486/06CC24CA9147/SIP/Error/sipSPIUpdateCallInfo:
007991: Mar 1 12:29:31.513: //68486/06CC24CA9147/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
007992: Mar 1 12:29:31.513: //68486/06CC24CA9147/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
007993: Mar 1 12:29:31.513: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
007994: Mar 1 12:29:31.513: //68486/06CC24CA9147/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=42BE8698-BCE
Date: Thu, 01 Mar 2018 12:29:31 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9391 8573 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007995: Mar 1 12:29:32.005: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007996: Mar 1 12:29:32.005: //68486/06CC24CA9147/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:32 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007997: Mar 1 12:29:33.001: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
007998: Mar 1 12:29:33.001: //68486/06CC24CA9147/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:33 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
007999: Mar 1 12:29:33.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
008000: Mar 1 12:29:33.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
008001: Mar 1 12:29:35.005: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008002: Mar 1 12:29:35.005: //68486/06CC24CA9147/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:35 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008003: Mar 1 12:29:37.149: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
008004: Mar 1 12:29:37.153: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
008005: Mar 1 12:29:37.153: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Thu, 01 Mar 2018 12:29:37 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
008006: Mar 1 12:29:37.229: //68483/00ECD6C1913F/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
008007: Mar 1 12:29:37.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 141
Contact: <42403000>
Content-Length: 0
008008: Mar 1 12:29:39.517: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKgv3ve7u5jive6j9gog3l9olje;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: ie3o3j9o6vvo5i3ie5ve5ljv6og97v5o@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008009: Mar 1 12:29:39.517: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
008010: Mar 1 12:29:39.521: //68487/0B9176239148/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
008011: Mar 1 12:29:39.521: //68487/0B9176239148/SIP/Error/sipSPIUpdateCallInfo:
008012: Mar 1 12:29:39.521: //68487/0B9176239148/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
008013: Mar 1 12:29:39.521: //68487/0B9176239148/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
008014: Mar 1 12:29:39.521: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
008015: Mar 1 12:29:39.521: //68487/0B9176239148/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=42BEA5DC-23C2
Date: Thu, 01 Mar 2018 12:29:39 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9614 7978 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008016: Mar 1 12:29:40.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008017: Mar 1 12:29:40.017: //68487/0B9176239148/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:40 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008018: Mar 1 12:29:41.013: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008019: Mar 1 12:29:41.013: //68487/0B9176239148/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:41 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008020: Mar 1 12:29:41.229: //68483/00ECD6C1913F/SIP/Error/act_sentrel1xx_wait_prack:
Out of retries state:14
008021: Mar 1 12:29:41.229: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
008022: Mar 1 12:29:41.229: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
008023: Mar 1 12:29:41.229: //68483/00ECD6C1913F/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer:
Invalid CCB/Data/Container
008024: Mar 1 12:29:41.229: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
008025: Mar 1 12:29:41.229: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
008026: Mar 1 12:29:41.229: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 504 Gateway Timeout
CSeq: 1 INVITE
Reason: Q.850;cause=102
Content-Length: 0
008027: Mar 1 12:29:41.229: //68483/00ECD6C1913F/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
008028: Mar 1 12:29:41.229: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:42403000@172.16.50.20:5060 SIP/2.0
To: <42403000>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1519907381
Content-Length: 0
008029: Mar 1 12:29:41.229: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName:
invalid ccb, bName or branch list for sipSPIRemoveBranchName
008030: Mar 1 12:29:41.229: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <42403000>
CSeq: 101 CANCEL
Content-Length: 0
008031: Mar 1 12:29:41.233: //68484/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
008032: Mar 1 12:29:41.233: //68484/00ECD6C1913F/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x165632B0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 77622027
Called Number : 42403000
Source IP Address (Sig ): 172.16.49.2
Destn SIP Req Addr:Port : 172.16.50.20:5060
Destn SIP Resp Addr:Port : 172.16.50.20:5060
Destination Name : 172.16.50.20
008033: Mar 1 12:29:41.233: //68484/00ECD6C1913F/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.16.49.2
Source IP Port (Media): 16664
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
008034: Mar 1 12:29:41.233: //68484/00ECD6C1913F/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 102
Disconnect Cause (SIP) : 487
008035: Mar 1 12:29:41.233: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:42403000@172.16.50.20:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
008036: Mar 1 12:29:41.729: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
008037: Mar 1 12:29:42.729: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
008038: Mar 1 12:29:43.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008039: Mar 1 12:29:43.017: //68487/0B9176239148/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:43 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008040: Mar 1 12:29:44.729: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
008041: Mar 1 12:29:47.525: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKhv43ghouuu63j7x9o4h7g9ljh;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 7ve5i6oj4lj5li437li9eoliu53iieo9@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008042: Mar 1 12:29:47.525: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
008043: Mar 1 12:29:47.525: //68488/1057643D9149/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
008044: Mar 1 12:29:47.525: //68488/1057643D9149/SIP/Error/sipSPIUpdateCallInfo:
008045: Mar 1 12:29:47.525: //68488/1057643D9149/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
008046: Mar 1 12:29:47.525: //68488/1057643D9149/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
008047: Mar 1 12:29:47.529: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
008048: Mar 1 12:29:47.529: //68488/1057643D9149/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=42BEC524-20CF
Date: Thu, 01 Mar 2018 12:29:47 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 554 2504 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008049: Mar 1 12:29:48.025: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008050: Mar 1 12:29:48.025: //68488/1057643D9149/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:48 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
008051: Mar 1 12:29:48.729: //68483/00ECD6C1913F/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
008052: Mar 1 12:29:49.021: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008053: Mar 1 12:29:49.021: //68488/1057643D9149/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:49 GMT
CSeq: 1 OPTIONS
Accept: applic
RTSF-T-01-04A-1#
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
u all
008054: Mar 1 12:29:51.025: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
008055: Mar 1 12:29:51.025: //68488/1057643D9149/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 01 Mar 2018 12:29:51 GMT
CSeq: 1 OPTIONS
Accept: applic
All possible debugging has been turned off
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
ringback not playing because your 180 ringing is not acknowledged by provider.
Check my above comment for actual reason
thanks for replywhat i supposed to do know?
You can check with Provider about not responding PRACK for 180 ringing .
Or you can disable 100rel from cube. This will just send 180 ringing to provider without sending "Require:100rel"
voice service voip
sip
rel1xx disable
thanks, could please help me and say what configuration i should do on cucm side that work.cause when i configure rel1xxx disable i got 500 internal server error.as i search in other forum this kind of ITSP. configuration is based on RFC.
thanks.
can you share your runnning configs. Referring to below logs, the problem remains the same. CUBE sending Require:100rel and provider not acknowledging it.
Have you contacted provider for this. In the initial Invite provider says he supports 100 rel an when Cube send it , the request is not acknowledged.
For more insights, you can refer to this doc.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/sbcu/2_xe/sbcu_2_xe_book/sbc_100rel.html
aaa session-id common
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone IRST 3 30
clock summer-time IRST date Mar 21 2016 0:00 Sep 22 2016 0:00
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
dsp services dspfarm
voice hunt user-busy
voice service voip
no ip address trusted authenticate
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no h225 timeout keepalive
sip
min-se 90 session-expires 300
registrar server
no silent-discard untrusted
no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice class sip-profiles 1
response 200 sip-header Require remove
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 2
rule 2 /^42403000/ /1350/
voice translation-profile AccessCode_Change
translate called 1
voice translation-profile IN
translate called 2
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 172.16.47.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.47.1
interface Loopback1
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.198.21.82 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.48.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 172.16.49.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn outgoing display-ie
isdn outgoing ie caller-number
no cdp enable
ip rtcp report interval 6000
ip route 10.153.101.165 255.255.255.255 10.198.21.81
control-plane
voice-port 0/0/0:15
connection plar 1900
voice-port 0/0/1:15
bearer-cap Speech
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
timeouts interdigit 3
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 1994
caller-id enable
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
connection plar opx 1250
caller-id enable
voice-port 1/0/12
connection plar opx 1900
caller-id enable
voice-port 1/0/13
cptone BR
timeouts call-disconnect 1
shutdown
impedance complex2
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 1/0/16
caller-id enable
voice-port 1/0/17
voice-port 1/0/18
connection plar opx 1993
caller-id enable
voice-port 1/0/19
connection plar opx 1992
caller-id enable
voice-port 1/0/20
connection plar opx 1995
caller-id enable
voice-port 1/0/21
connection plar 1124
caller-id enable
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
caller-id enable
voice-port 2/0/10
connection plar opx 1991
caller-id enable
voice-port 2/0/11
caller-id enable
voice-port 2/0/12
connection plar opx 1124
caller-id enable
voice-port 2/0/13
connection plar opx 1990
caller-id enable
voice-port 2/0/16
cptone BR
connection plar opx 1110
impedance complex2
caller-id enable
voice-port 2/0/17
caller-id enable
voice-port 2/0/18
caller-id enable
voice-port 2/0/19
cptone BR
connection plar opx 1119
impedance complex2
caller-id enable
voice-port 2/0/20
supervisory custom-cptone IR1
caller-id enable
voice-port 2/0/21
caller-id enable
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/0/2
voice-port 3/0/3
voice-port 3/0/4
voice-port 3/0/5
voice-port 3/0/6
voice-port 3/0/7
voice-port 3/0/8
voice-port 3/0/9
voice-port 3/0/10
caller-id enable
voice-port 3/0/11
caller-id enable
voice-port 3/0/12
caller-id enable
voice-port 3/0/13
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local Loopback0
sccp ccm 172.16.50.20 identifier 1 version 7.0
sccp ccm 172.16.50.21 identifier 2 version 7.0
sccp ccm 172.17.50.21 identifier 3 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate ccm 3 priority 3
associate profile 2 register CFB_HW
associate profile 1 register XCODE_HW
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec pass-through
maximum sessions 8
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
dial-peer cor custom
dial-peer cor list xx
member xx
member xx
member xx
member xx
member xx
member xx
dial-peer cor list user-xx
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
destination-pattern 5000
forward-digits all
dial-peer voice 100 pots
destination-pattern 1[13]..
port 0/0/1:15
forward-digits all
dial-peer voice 101 pots
destination-pattern 16..
port 0/0/1:15
forward-digits all
dial-peer voice 102 pots
corlist incoming
corlist outgoing
destination-pattern 9T
port 0/0/1:15
forward-digits all
dial-peer voice 103 pots
destination-pattern 2...
port 0/0/1:15
forward-digits all
dial-peer voice 104 pots
destination-pattern 4...
port 0/0/1:15
forward-digits all
dial-peer voice 250 voip
corlist incoming
answer-address 125[0-7]
no vad
dial-peer voice 251 voip
corlist incoming
answer-address 127[0-6]
no vad
dial-peer voice 252 voip
corlist incoming
answer-address 129[01]
no vad
dial-peer voice 253 voip
corlist incoming
answer-address 120[12]
no vad
dial-peer voice 205 pots
corlist incoming
corlist outgoing
port 1/0/8
dial-peer voice 206 pots
corlist outgoing
port 1/0/11
dial-peer voice 207 pots
corlist outgoing
preference 1
port 1/0/12
dial-peer voice 208 pots
corlist outgoing
port 1/0/13
dial-peer voice 209 pots
corlist outgoing
preference 1
port 1/0/16
dial-peer voice 210 pots
corlist incoming
corlist outgoing
port 1/0/18
dial-peer voice 211 pots
corlist incoming
corlist outgoing
port 1/0/19
dial-peer voice 212 pots
corlist incoming
corlist outgoing
port 1/0/20
dial-peer voice 213 pots
corlist outgoing
port 1/0/21
dial-peer voice 214 pots
corlist incoming
corlist outgoing
port 3/0/10
dial-peer voice 215 pots
corlist outgoing
preference 1
port 3/0/11
dial-peer voice 216 pots
corlist outgoing
preference 1
port 3/0/13
dial-peer voice 217 pots
corlist outgoing
port 2/0/9
dial-peer voice 218 pots
corlist incoming
corlist outgoing
port 2/0/10
dial-peer voice 219 pots
corlist outgoing
preference 1
port 2/0/11
dial-peer voice 220 pots
corlist outgoing
port 2/0/12
dial-peer voice 221 pots
corlist incoming
corlist outgoing
fax rate voice
port 2/0/13
dial-peer voice 222 pots
corlist outgoing
port 2/0/16
dial-peer voice 223 pots
corlist outgoing
port 2/0/17
dial-peer voice 224 pots
corlist outgoing
port 2/0/18
dial-peer voice 225 pots
corlist outgoing
port 2/0/19
dial-peer voice 226 pots
corlist outgoing
port 2/0/20
dial-peer voice 227 pots
corlist outgoing
port 2/0/21
dial-peer voice 254 voip
corlist incoming
answer-address 112[56]
no vad
dial-peer voice 255 voip
corlist incoming
answer-address 112[34]
no vad
dial-peer voice 256 voip
corlist incoming
answer-address 1118
no vad
dial-peer voice 258 voip
corlist incoming
answer-address 1109
no vad
dial-peer voice 259 voip
corlist incoming
answer-address 1110
no vad
dial-peer voice 260 voip
corlist incoming
answer-address 111[12]
no vad
dial-peer voice 261 voip
corlist incoming
answer-address 13[0124][02-9]
no vad
dial-peer voice 262 voip
corlist incoming
answer-address 111[34]
no vad
dial-peer voice 263 voip
corlist incoming
answer-address 13[57][02-6]
no vad
dial-peer voice 264 voip
corlist incoming
answer-address 140[01]
no vad
dial-peer voice 265 voip
corlist incoming
answer-address 147[5789]
no vad
dial-peer voice 266 voip
corlist incomin
answer-address 150[0156]
no vad
dial-peer voice 267 voip
corlist incoming
corlist outgoing
answer-address 1990
codec g711alaw
no vad
dial-peer voice 268 voip
corlist incoming
corlist outgoing
answer-address 1991
codec g711alaw
no vad
dial-peer voice 269 voip
corlist incoming
corlist outgoing
answer-address 1992
codec g711alaw
no vad
dial-peer voice 270 voip
corlist incoming
corlist outgoing
answer-address 1993
codec g711alaw
no vad
dial-peer voice 271 voip
corlist incoming
corlist outgoing
answer-address 1994
codec g711alaw
no vad
dial-peer voice 272 voip
corlist incoming
corlist outgoing
answer-address 1995
codec g711alaw
no vad
dial-peer voice 273 voip
corlist incoming
answer-address ....
no vad
dial-peer voice 275 voip
corlist incoming
answer-address 1801
no vad
dial-peer voice 276 voip
corlist incoming
answer-address 1802
no vad
dial-peer voice 277 voip
corlist incoming
answer-address 1803
no vad
dial-peer voice 278 voip
corlist incoming
answer-address 1804
no vad
dial-peer voice 279 voip
corlist incoming
answer-address 1805
no vad
dial-peer voice 280 voip
corlist incoming
answer-address 1806
no vad
dial-peer voice 281 voip
corlist in
answer-address 1807
no vad
dial-peer voice 282 voip
corlist incoming
answer-address 1808
no vad
dial-peer voice 283 voip
corlist incoming
answer-address 1809
no vad
dial-peer voice 284 voip
corlist incoming
answer-address 1810
no vad
dial-peer voice 285 voip
corlist incoming
answer-address 1534
no vad
dial-peer voice 228 pots
corlist outgoing
port 3/0/12
dial-peer voice 274 voip
corlist incoming
answer-address 1208
no vad
dial-peer voice 257 voip
corlist incoming
answer-address 1108
no vad
dial-peer voice 10 voip
preference 2
destination-pattern 1[123458]..
session target ipv4:172.16.50.20
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric rtp-nte
no vad
dial-peer voice 11 voip
preference 1
session target ipv4:172.16.50.21
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 12 voip
session target ipv4:172.17.50.21
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 13 voip
description FOR UCCX
destination-pattern 19..
no modem passthrough
voice-class h323 1
codec g711alaw
fax-relay sg3-to-g3
fax protocol pass-through g711alaw
no vad
dial-peer voice 14 voip
preference 1
voice-class h323 1
codec g711alaw
no vad
dial-peer voice 311 voip
destination-pattern 42403000
session protocol sipv2
voice-class sip dtmf-relay force rtp-nte
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte digit-drop
codec g711alaw
no vad
dial-peer voice 312 voip
session target ipv4:10.153.101.165
incoming called-number 42403000
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
codec g711alaw
no vad
gateway
media-inactivity-criteria all
timer receive-rtcp 600
timer receive-rtp 1200
sip-ua
gatekeeper
shutdown
1.Have you checked with provider on this case.You can ask provider to either ack provisional responses or do not send 100rel in supported header in INVITE.
2. i do not see and rel1xx disable coomand in above configs. Configure it under the incoming dial-peer toward provider or globally. try both
3. If still above 2 cases don't work then you can use sip-profiles to remove/ edit supported header locally in your router.
3. I
1.I checked the sip trunk with Elastix is worked for outgoing and incoming
call. (Cause Provider Told That)
2.I configured the sip trunk on cucm and don't used cube it worked for both
incoming and outgoing but the dtmf does't work on that configuration.
3.when i configure again the sip trunk on cube it does't work. (even when i
disable the rel1xx on voice service voip)
